Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Inventor 2012 SP1 Installati on Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I finally got Inventor 2012 updated to SP1 by using the Autodesk Live Update instead of the msi download file.
Nothing suggested here helped to get the msi download to work.
I've no idea why the Live Update worked and the msi download wouldn't.
Chris Hutchinson
Duke Energy
Charlotte, NC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The error should be a rare event on only XP32bit, and I never see it again once encounter it on a machine.I means I can install SP1 successfully after cancelling the first failed install.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Chrishutchinson.
Could you please indicate us which OS are you using ?
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Pierre, I'm using Windows XP Pro 32 bit SP3 OS.
Chris Hutchinson
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Last night before I left work I tried to install via Live Update and apparently it went through without issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
You can also do this:
-Start Inventor 2012 Sp0
-Start installing Sp1 (while Inventor is running)
-Close inventor when the installation require it, and click resume.
Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
HP EliteBook 8560w
Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
16GB RAM
Windows 7 X64 SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had the same problem with the registry key error trying to install SP1 on a 32-bit XP SP3 computer. Yes, I have admin rights. Not sure why SP1 seems to have an incorrect path for the registry key it wants to edit.
All of my 64-bit XP SP3 computers had no issues with their copy of SP1.
Having Inventor running while I installed SP1, and then closing Inventor when prompted, let me finally get the 32-bit SP1 installed. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have the same problem with XP 32-bit, tried downloading the msi three times.
I tried installing with Inventor open and then the installation compeleted without thorowing any errors.
Inventor Professional 2012 SP1 (25 seats with subscription)
Windows 7 64 bit
Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
Quadro 4000, driver 8.17.12.9573, dual monitors
SpacePilot, driver version 6.15.3 Firmware 3.12
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Doesn't anybody noticed that the path from the error message is incorrect because contains double backslash?
HKEY_LOCAL_MACHINE\Software\Autodesk\\RegistryVers
The popup complains something you don't have sufficient access to the path.
- yes, that's correct, because the specified path doesn't exist!
That's just Autodesk fault. On my Win XP SP3 32bit it works to start installing the SP1with runned Inventor and right after few seconds close the Inventor.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
