• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    jrm_1971
    Inventor 2012 Pro - flat pattern for a solid
    227 Views, 2 Replies
    11-09-2012 01:58 PM
    Is there a way, in an .idw (drawing file) to create a flat view (unrolled) of a cylindrical solid? NOT to be confused with sheet metal. This is from a solid .ipt. Either that or create a flat pattern of a solid cylinder that IS NOT SHEET METAL?
    Please use plain text.
    Valued Mentor
    Re: Inventor 2012 Pro - flat pattern for a solid
    11-09-2012 07:40 PM in reply to: jrm_1971
    ok well not too sure if this still falls within your allowable methodology, but maybe if you want to, you could derive the cylinder into a new sheet metal part, ipt (choose import as a surface). Then just thicken the outer skin, rip it and flatten it.
    when you save the file, just call it the same file name as the main part but add a postfix to the name to indicate that it is related information.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    *Expert Elite*
    11-10-2012 05:40 AM in reply to: jrm_1971
    Sheet metal is just a term for a catagory of specialized tools.
    Attach your file here.
    Inventor Professional 2014 Edu 64-bit
