Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Inventor 2012 Pro - flat pattern for a solid
Options
- Highlight
- Email to a Friend
210 Views, 2 Replies
11-09-2012 01:58 PM
Is there a way, in an .idw (drawing file) to create a flat view (unrolled) of a cylindrical solid? NOT to be confused with sheet metal. This is from a solid .ipt. Either that or create a flat pattern of a solid cylinder that IS NOT SHEET METAL?
Re: Inventor 2012 Pro - flat pattern for a solid
Options
- Highlight
- Email to a Friend
11-09-2012 07:40 PM in reply to:
jrm_1971
ok well not too sure if this still falls within your allowable methodology, but maybe if you want to, you could derive the cylinder into a new sheet metal part, ipt (choose import as a surface). Then just thicken the outer skin, rip it and flatten it.
when you save the file, just call it the same file name as the main part but add a postfix to the name to indicate that it is related information.
-Mark
Inventor 2014 Pro on Windows 7, 64bit
(please give Kudos or Tag as Solved if your issue is resolved)
Options
- Highlight
- Email to a Friend
11-10-2012 05:40 AM in reply to:
jrm_1971
Sheet metal is just a term for a catagory of specialized tools.
Attach your file here.
