• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Inventor 2012 Pro, FEA Report & "Max Stress" error
    117 Views, 2 Replies
    12-10-2012 12:50 PM
    I've encountered a discrepancy in the "max stress" probe on the Von Mises results of a stress analysis & the Von Mises min/max in the results section of the report I've just printed off.
    My model shows a max von mises of 349.5MPa & the results section of the report shows a max von mises of 457.3MPa.
    How is this so? How do I fix it ?
    Inventor 2012 SP2
    Xeon E5410 2.33 GHz
    8 Gb RAM
    Quadro FX1700
    Vista 64 Bit SP2
    Please use plain text.
    Active Member
    Re: Inventor 2012 Pro, FEA Report & "Max Stress" error
    02-25-2013 06:14 PM in reply to: mta-rmt
    Anyone got else found this problem ?
    I still have this issue.
    Inventor 2012 SP2
    Xeon E5410 2.33 GHz
    8 Gb RAM
    Quadro FX1700
    Vista 64 Bit SP2
    Active Member
    02-26-2013 03:20 PM in reply to: mta-rmt
    I have a solution, which is to delete the various fea analyses ascociated with the assembly, do a rebuild of the assembly and start new analyses from scratch. This seems to have solved the issue.
    However you still need to be wary of the figures quoted in the results table of reports.
    Inventor 2012 SP2
    Xeon E5410 2.33 GHz
    8 Gb RAM
    Quadro FX1700
    Vista 64 Bit SP2
