• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Inventor 2012 - Export to PDF - Quality is Terrible
    924 Views, 14 Replies
    10-04-2012 08:11 AM
    Is it possible to increase the quality of exported pdf's from Inventor 2012?  Anything with a metalic (ie. black chrome) finish as a pdf looks terrible when compared to what is shown on screen.
    Please use plain text.
    Member
    Re: Inventor 2012 - Export to PDF - Quality is Terrible
    10-09-2012 06:59 AM in reply to: cascadety
    Really?? No experts on boad that know a procedure to increase the quality of pdf's created using the "export" function from Inventor 2012?
    Let me clarify:
    On screen part/assembly/drawing quality - Excellent
    Print quality - Excellent
    PDF quality - Marginal (as in bitmap / low-res)
    Any Ideas?
    Valued Mentor
    mpatchus
    10-09-2012 07:57 AM in reply to: cascadety
    Maybe an example of what you are seeing would help.
    I've gotten reasonable results of PDF exports (see attached)
    Not nearly as good as rendered images, but decent enough to use in-house.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Member
    10-09-2012 09:40 AM in reply to: mpatchus
    Hey,
    Thanks for the response and suggestion.  Your pdf seems to have much better clarity than any I create using the export command.  See attached example "mesh.pdf" file.
    Our company uses BlueBleam pdf creator for the majority of our pdfs.  However, it only intergrates with AutoCAD and not Inventor.  Using BlueBeam as a printer in Inventor produces worse results than exporting.  See attached "mesh BB.pdf" file .
    Additionally, the goal for these pdf's is to use out-of-house.
    Distinguished Contributor
    Ryan.Martinez
    10-09-2012 10:32 AM in reply to: cascadety
    Did you try changing the vector resolution in the export options?
    Product Design Suite 2013
    *Expert Elite*
    blair
    10-09-2012 10:34 AM in reply to: Ryan.Martinez
    Did you increase the DPI resolution when using the Export to PDF (in the Options when doing the export).
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Member
    10-09-2012 11:16 AM in reply to: blair
    Thanks for the responses.  Increased the resoluion to 4800 and it did help some.  It appears to be the nature of the coil spring mesh in the black chrome surface tho.  Parts in other finishes look much better.
    Thanks again
    Member
    10-10-2012 12:13 PM in reply to: cascadety
    My company uses CutePDF writer, and it works for what we do.  Whenever I print something that has a perforated or checker plate material applied to it, it comes out just fine.
    Valued Mentor
    mpatchus
    10-11-2012 03:58 AM in reply to: cascadety
    We have stopped using print add-ons to create the PDFs.  We've found exporting the file as a PDF produces better results than "printing" as a PDF.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Member
    10-11-2012 05:32 AM in reply to: mpatchus
    Oh my, I did not realize how nice the export to PDF option is.  Blueprint quality is very much improved.
    I'll be using the export feature from now on - thank you!
