• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Employee
    Re: Inventor 2012 Crash Problems
    02-22-2012 09:35 AM in reply to: psohaney
    Can you email me your IPT file. I can take a look and see why its crashing. If you open the IPT stand-alone, can you open it? If not, its probably not related to this hotfix and could be some other issue.
    You can reach me at sundarsATautodeskDOTcom.
    -Shiva Sundaram
    Inventor Development
    Please use plain text.
    02-22-2012 09:38 AM in reply to: Shiva_Sundaram
    Just sent you an email pertaining to this.  I cannot open ANY IPT file at this point without the program quitting.
    Employee
    02-22-2012 09:57 AM in reply to: psohaney
    I got your file and can open it fine in R2012 SP1. The crash is most likely not related to this hotfix or R2012 SP1, but perhaps due to outdated graphics drivers or anti-virus or some other issue which is preventing the software from working normally.
    Could you please try updating your graphics card drivers and let me know what you find.
    -Shiva Sundaram
    Mark_Flayler
    02-22-2012 10:02 AM in reply to: Shiva_Sundaram
    Tangental question...
    Are you using and shadows or realistic visual styles as your default appliation options?  I have found that on occasion with the application settings set a specified way that it will corrupt my user profile and the only way to fix Inventor is to delete my user profile with an admin account and then recreate it.
    Mark Flayler Application Engineer - Manufacturing Solutions Division
    IMAGINiT's Manufacturing Solutions Blog:
    http://blogs.rand.com/manufacturing/
    02-22-2012 01:38 PM in reply to: Shiva_Sundaram
    Updating the ATI graphics card with the most current version was the key.  Seems to have settled the CRASH bug for good.  I will know after I stretch it's legs for a while.
    New Member
    01-27-2013 10:13 AM in reply to: Breemum
    Hi guys!
    First of all, sorry for my english.. I have crashes all the time with Inventor Professional 2012 64-bit, if i want to open a larger assembly. Will be the problem, that my computer isn't good? The workstations in my workplace are worse, and they can open it.
    My computer:
    OS: Windows 7 Ultimate 64bit
    MB: ASUS M4A79XTD EVO
    CPU: AMD Phenom X4 955 Quad Core 3.2 GHz
    VGA: ASUS Radeon HD 6870
    RAM: Kingmax 4GB 1333MHz (i know that this is few, but the workstations have 3,5 only..)
    HDD: WD 1TB 7200rpm SATA
    Valued Mentor
    01-28-2013 05:19 AM in reply to: Shiva_Sundaram
    hi,
    sorry if you already checked this but,
    just firstly make sure that you have the latest service pack for your version of inventor and update your graphics card drivers at the same time.
    then see how it goes.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
