• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Re: Inventor 2012 Crash Problems
    10-26-2011 06:18 AM in reply to: Shiva_Sundaram
    Shiva:
    I am having MANY crashes while in the .idw environment, too.  How come Autodesk has not suggested this fix for me?
    Steve Frey
    Inventor 2013
    Windows 7 Professional 64-bit SP1
    HP EliteBook 8470w
    Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
    Memory: 16 GB
    AMD FirePro M2000
    3D Connexion SpacePilot
    Please use plain text.
    10-26-2011 06:24 AM in reply to: SteveFrey
    I've been going back and forth with Autodesk on this issue for weeks and they keep blaming it on my system.  My IT dept says this is not the case.  I don't know what to do at this point.  Autodesk swears up and down that it is not their problem.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    New Member
    SMitchellHME
    10-26-2011 06:29 AM in reply to: SteveFrey
    As a member of my company's IT group, I feel your pain Steve. We have downloaded every file, installed every patch, and checked/unchecked every option. I hope AutoDesk may resolve your issue soon! We'll be here waiting to see, along with you.
    10-26-2011 06:45 AM in reply to: SMitchellHME
    Thanks for your understanding.  The only way I can create an .idw is to save it every 30 seconds.  What a joke.  Solidworks here I come!
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    Active Member
    dpaskman
    10-26-2011 07:00 AM in reply to: Breemum
    Help!!  I need to get this drawing now and I am crashing everytime I try and place a drawing view from the model.  The model is large but I have SP1 installed and still crashing
    Employee
    10-26-2011 07:04 AM in reply to: dpaskman
    Hi Alll,
    We have been working on these crashes and we hope to release a hotfix ASAP. There have been a couple of triggers which are causing these crashes (a) selection and undo (b) select-other and undo (c) interaction with add-ins
    These are not necessarily related to the "Enable background updates" - we did have a couple of issues in the past with this functionality that was fixed back in SP1.
    We hope to roll this out as quickly as we can. We apologize (and we really mean it) for the inconvenience.
    One thing which would help is if you can send me your email address so that I can track the crash reports and ensure that the issues are already fixed (or will be fixed by the hotfix).
    You can email me at: sundarsATautodeskDOTcom
    Thanks and our apologies once again.
    -Shiva Sundaram
    Inventor Development
    Employee
    10-26-2011 07:10 AM in reply to: dpaskman
    Hi All (and dpaskman)
    I would like to also like to add that if you feel that you just crashing trying to create a drawing view, then its probably not a generic issue and might be model related. Perhaps there is some bad geometry or translated data.
    I would be happy to take a look at those issues - please email me your email address, I can initially track the crash in our database which would help figure out what was going wrong.
    In addition, you can send me your model files and drawing files with some instructions on how to reproduce this and your machine configuration (graphics info etc).
    You can contact me at: sundarsATautodeskDOTcom.
    -Shiva Sundaram
    Member
    slayer5608
    10-26-2011 12:56 PM in reply to: Breemum
    Hello, I just have a quick question. I just had Inventor crash on me and I didn't save, is there a recovery mode like autocad has or am I basically SOL? Thanks in advance for the help on this matter
    Employee
    10-27-2011 06:53 AM in reply to: slayer5608
    All.
    I have some good news. We have issued a hotfix which addresses many of the instabilities in drawings in R2012.
    Please note that this would need to be applied on top of R2012 SP1. If you don't have R2012 SP1 installed, please install R2012 SP1 prior to installing the hotfix. The readme describes the issues fixed as well as installation instructions.
    The hotfix DL17804781 can be found at:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17804781&linkID=9242019
    Thanks for your patience and we apologize for the inconvenience caused.
    -Shiva Sundaram
    02-22-2012 09:32 AM in reply to: Shiva_Sundaram
    Intalled this patch, and Inventor 2012 STILL continues to crash when I attempt to open an IPT model that was created in 2012 originally.  The model is stable, as I had created it on previous installation of 2012.
