• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Re: Inventor 2011 Rendering
    08-27-2010 09:40 AM in reply to: LotzH
    I had the same issue.  There is a hotfix issued to address it for 2011.  Try applying the patch and see if this fixes it.
    Please use plain text.
    Active Contributor
    08-27-2010 09:59 AM in reply to: askseddon
    I applied the patch about a week ago and it has been working fine since.
    Active Member
    YS_WM
    08-27-2010 11:07 AM in reply to: askseddon
    Did you apply the same hotfix I did?  DL15293597
    If not, can you please give me a link to the hotfix?
    Active Contributor
    08-27-2010 11:09 AM in reply to: YS_WM
    This is the one.
    Active Member
    YS_WM
    08-27-2010 11:16 AM in reply to: askseddon
    Thanks, I will try to reinstall it. Do you know if there are any problems with the installation for win7 64-bit?
    Active Contributor
    08-27-2010 11:18 AM in reply to: YS_WM
    Sorry I do not know, I am stuck in the dark ages using XP 64!
    Active Member
    YS_WM
    08-27-2010 11:20 AM in reply to: askseddon
    Thanks anyway, I will reinstalling and simulating again over night.
    Active Member
    YS_WM
    08-27-2010 02:19 PM in reply to: askseddon
    I have installed the hotfix and tried to render again. NO SUCCESS. Just like before, the memory usage is claiming higher and higher. Right now it finished rendering 7 out of 1100 frames and it used 17.1GB out of 18GB.
    Can anyone help me solve this problem?
    OS: Windows 7 pro 64-bit.
    Model: HP HPE-180t.
    CPU: Intel Core i7 CPU  950 @ 3.07GHZ.
    Memory: 18.0 GB
    Display adapter: NVIDIA GeForce GTX 260
    *Expert Elite*
    karthur1
    08-27-2010 02:24 PM in reply to: YS_WM
    I just noticed that they just posted 2011 SP1.  Might give that a go.
    Active Member
    YS_WM
    08-30-2010 06:35 AM in reply to: askseddon
    Ok, So I've installed SP1 this morning and tried to run the simulation again. After 8 out of 1100 frames the computer have used 11GB of memory. The assembly is big but not something my computer should not handel, right?! I have 224 open documents in session and 504 occurrences in active document.
    Attached are the setting to the rendering.
    Am I doing anything wrong? I am out of ideas.
    Model: HP HPE-180t.
    Memory: 18.0 GB
    AutoCAD Inventor Suite 2011 64-Bit Edition SP1
