• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Inventor 2010 import dwg issue
    90 Views, 3 Replies
    04-16-2012 07:52 PM
    Hi all.
    For over a year i have been using dwg import quite succesfully ( most recently about 3 weeks ago) now all of a sudden it doesnt work.
    I have tried the option to "open" then select import under "options" but literally nothing happens. The open window closes and its finished. Doesnt even  open the import options window.
    I tried to import by clicking "Insert" ACAD on the sketch ribbon bar ...same result
    I thought it may have been the dwg i was tryng to import so i created a simple dwg to try . Still no luck
    Im using Inventor 2010 Pro on a Win7 64 bit PC
    All help appreciatted
    Please use plain text.
    Valued Mentor
    Mike.Wohletz
    Re: Inventor 2010 import dwg issue
    04-16-2012 07:59 PM in reply to: bigfilsing
    Are you able to open the file with DWGTrue View? if so have you recently updated DWGTrue View to a newer version? This is what Inventor uses to translate AutoCAD DWG files so it is important that it is working and I would try to keep the versions the same if possible.
    Active Contributor
    04-17-2012 12:12 AM in reply to: Mike.Wohletz
    Hi Mike thanks for the quick reply
    I havent used DWG True view for a while and certainly havent updated it.
    I will try some thing out later and report back
    I have updated Inventor 2010 all the way to SP4 and thinking back the issues may have arrived since the update from SP3 to SP4.
    Ill get back to you
    Regards
    Phil
    Active Contributor
    04-17-2012 07:24 AM in reply to: bigfilsing
    Well what do you know . i opened the dwg in true view and it worked fine. Then went back and tried again in Inventor.
    Now all of a sudden it works .!!
    Thanks for the direction Mike
