Inventor Forum
Inventor 2010 flexnet license error!
15 REPLIES 15
Message 1 of 16
perhaps
2598 Views, 15 Replies
In the common course of first activation, a liceseing screen screen will show before the main program.
But I click the inventor icon on the desktop, nothing happens!
I insert a system variable:FLEXLM_DIAGNOSTICS and valued it as 3
I got the folloing msg:
Checkout error returned from FLEXnet:No such feature exists.
FLEX Feature: INVPRO_F_S
License path:
FLEXnet Licensing error: -5, 357
I have uninstalled all the parts of inventor 2010 professional suits , cleaned all autodesk items in the registry
and reinstall inventor 2010, but it didn't help!
my computer is thinkpad x200
and the system is xp x86 with 4G ddr3-1066 ram
anybody can solve this problem?HELP! Edited by: perhaps on Jun 16, 2009 4:18 PM
15 REPLIES 15
Message 2 of 16
in reply to: perhaps
Did you configure LMTOOLS as using a service or a license
file?
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 3 of 16
perhaps
yes, I also installed ansys and nastran in my computer.
They are using LMTOOLS as license manager.
But I don't find any license manager during installation of inventor.
According to successful installation, I will input the activation code in the first time.
but the license screen did'nt show.
Message 4 of 16
Did you install Inventor with Standalone
license(default selection) or Network license(need to input server name when you
configure Inventor)?
if it is standalone, after you click the shortcut
of Inventor, open task manager, can you see Inventor.exe process
started?
if it is network license, you have to install
LMTools from Tools and Utility, you can find it on the first launch page after
you start setup.exe.then get a network license from Autodesk and import
LMTools.
Message 5 of 16
To add to Kevin's reply. If you have a network version and you
have FLEXLM version 10.8 or above, you should be able to add the Autodesk .lic
file as a separate service on the same Flex server.
If you need more assistance with netowork licensing
of ANY Autodesk product, go to the autodesk.autocad.network discussion
group.
Expert
Expert.
AIP 2008 SP3,
Message 6 of 16
perhaps
my installation is standalone.
after click the shortcut, harddisk light will blink for about one minute,
but NO inventor.exe process shows in task manager. Edited by: perhaps on Jun 17, 2009 9:21 AM
Message 7 of 16
Did you install following these guidelines?
Expert
Expert.
AIP 2008 SP3,
Message 8 of 16
perhaps
sorry, I made a mistake:
after click the shortcut, inventor.exe process will SHOW in task manager.
then "flexible license manager" window will pop up and tell me flexnet licensing check out error
seconds later a system warning sound "bang"
and inventor.exe process will disappear.
Message 9 of 16
perhaps
Disable all antivirus services
is this really Critical?
I'm using avast!
and successfully installed inventor 2010 on win7 RC7127.
it confuse me what's wrong with winxp
Message 10 of 16
Yes it is critical. So is turning off th UAC. I would not have
listed them if they were not critical steps.
BTW, I run Avast! on my xp64 , and I always turn off all
Avaste services before any install.
Expert
Expert.
AIP 2008 SP3,
Message 11 of 16
perhaps
reinstall( with anvirus software shutdown) and fail again!
But I find an error report in
C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM
INVPRO2010CHSAdLM.log
3948 2009/06/18 19:59:27 Reason=Fatal error
3948 2009/06/18 19:59:27 ComputerName=HZNOTEBOOK
3948 2009/06/18 19:59:27 OS=5.0.2195.
3948 2009/06/18 19:59:27 File=AdlmFlxActTS.cpp,Line=560
3948 2009/06/18 19:59:27 AdlmActError=8 [An item is not found]
3948 2009/06/18 19:59:27 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=361
3948 2009/06/18 19:59:27 AdlmActError=18 [Argument to a function is bad]
2420 2009/06/18 19:59:27 Reason=Fatal error
2420 2009/06/18 19:59:27 ComputerName=HZNOTEBOOK
2420 2009/06/18 19:59:27 OS=5.0.2195.
2420 2009/06/18 19:59:27 File=AdlmIntSATSLicense.cpp,Line=347
2420 2009/06/18 19:59:27 VendorID=2 [ADLMACT]
2420 2009/06/18 19:59:27 VendorError=18 [Argument to a function is bad]
HELP!
Message 12 of 16
Can you provide full system specs on your laptop - Make,
model, Total RAM, CPU, Graphics Card and Graphics drive version, OS version and
Service Pack level, All windows hotfixes and updates installed?
Did you do a complete uninstall of Inventor 2010 prior to
attempting the reinstall, including deletion of entries in Program files,
Documents and Settings > All users and your username?
Expert
Expert.
AIP 2008 SP3,
Message 13 of 16
perhaps
I'm installing inventor on my laptop, thinkpad x200
250G hard disk and only one partition c:
centrino 2 P8600,GMA 4500MHD graphic card
4G DDR3 1066MHz ram , winxp pro sp3 with all hotfix and updates installed.
and yes, I do a complete uninstall and clean the registry.
Message 14 of 16
I have no more ideas without seeing the laptop... maybe
someone else may be able to help.
Expert
Expert.
AIP 2008 SP3,
Message 15 of 16
perhaps
This problem has been resovled!
legacy_autodesk_licensing_service and Autodesk licensing service must be deleted before any re-installation.
For a start I got a .bat file from regscanner to delete all keys with "autodesk" and "inventor 2010" automatically and failed N times after re-installtion. Then I got some help from GOOGLE that legacy_autodesk_licensing_service(HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\)
would NOT be deleted if u don't change its permission to "FULL CONTROL"(EVERYONE) (right mouse, permission)
thx a lot all the same!
Message 16 of 16
LFQUIROZ
5284 2012/04/12 13:38:02 Reason=Fatal error
5284 2012/04/12 13:38:02 ComputerName=OWNER-PC
5284 2012/04/12 13:38:02 OS=6.1.7601.Service Pack 1
5284 2012/04/12 13:38:02 File=AdlmFlxActTS.cpp,Line=611
5284 2012/04/12 13:38:02 AdlmActError=8 [An item is not found]
5284 2012/04/12 13:38:02 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
5284 2012/04/12 13:38:02 AdlmActError=18 [Argument to a function is bad]
2292 2012/04/12 13:38:03 Reason=Fatal error
2292 2012/04/12 13:38:03 ComputerName=OWNER-PC
2292 2012/04/12 13:38:03 OS=6.1.7601.Service Pack 1
2292 2012/04/12 13:38:03 File=AdlmIntSATSLicense.cpp,Line=416
2292 2012/04/12 13:38:03 VendorID=2 [ADLMACT]
2292 2012/04/12 13:38:03 VendorError=18 [Argument to a function is bad]
3496 2012/04/12 13:38:38 Reason=Fatal error
3496 2012/04/12 13:38:38 ComputerName=OWNER-PC
3496 2012/04/12 13:38:38 OS=6.1.7601.Service Pack 1
3496 2012/04/12 13:38:38 File=AdlmFlxActTS.cpp,Line=611
3496 2012/04/12 13:38:38 AdlmActError=8 [An item is not found]
3496 2012/04/12 13:38:38 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
3496 2012/04/12 13:38:38 AdlmActError=18 [Argument to a function is bad]
2736 2012/04/12 13:38:38 Reason=Fatal error
2736 2012/04/12 13:38:38 ComputerName=OWNER-PC
2736 2012/04/12 13:38:38 OS=6.1.7601.Service Pack 1
2736 2012/04/12 13:38:38 File=AdlmIntSATSLicense.cpp,Line=416
2736 2012/04/12 13:38:38 VendorID=2 [ADLMACT]
2736 2012/04/12 13:38:38 VendorError=18 [Argument to a function is bad]
5764 2012/04/12 13:41:36 Reason=Fatal error
5764 2012/04/12 13:41:36 ComputerName=OWNER-PC
5764 2012/04/12 13:41:36 OS=6.1.7601.Service Pack 1
5764 2012/04/12 13:41:36 File=AdlmFlxActTS.cpp,Line=611
5764 2012/04/12 13:41:36 AdlmActError=8 [An item is not found]
5764 2012/04/12 13:41:36 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
5764 2012/04/12 13:41:36 AdlmActError=18 [Argument to a function is bad]
4640 2012/04/12 13:41:36 Reason=Fatal error
4640 2012/04/12 13:41:36 ComputerName=OWNER-PC
4640 2012/04/12 13:41:36 OS=6.1.7601.Service Pack 1
4640 2012/04/12 13:41:36 File=AdlmIntSATSLicense.cpp,Line=416
4640 2012/04/12 13:41:36 VendorID=2 [ADLMACT]
4640 2012/04/12 13:41:36 VendorError=18 [Argument to a function is bad]
5524 2012/04/12 13:42:17 Reason=Fatal error
5524 2012/04/12 13:42:17 ComputerName=OWNER-PC
5524 2012/04/12 13:42:17 OS=6.1.7601.Service Pack 1
5524 2012/04/12 13:42:17 File=AdlmFlxActTS.cpp,Line=611
5524 2012/04/12 13:42:17 AdlmActError=8 [An item is not found]
5524 2012/04/12 13:42:17 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
5524 2012/04/12 13:42:17 AdlmActError=18 [Argument to a function is bad]
4752 2012/04/12 13:42:18 Reason=Fatal error
4752 2012/04/12 13:42:18 ComputerName=OWNER-PC
4752 2012/04/12 13:42:18 OS=6.1.7601.Service Pack 1
4752 2012/04/12 13:42:18 File=AdlmIntSATSLicense.cpp,Line=416
4752 2012/04/12 13:42:18 VendorID=2 [ADLMACT]
4752 2012/04/12 13:42:18 VendorError=18 [Argument to a function is bad]
4104 2012/04/12 22:00:09 Reason=Fatal error
4104 2012/04/12 22:00:09 ComputerName=OWNER-PC
4104 2012/04/12 22:00:09 OS=6.1.7601.Service Pack 1
4104 2012/04/12 22:00:09 File=AdlmFlxActTS.cpp,Line=611
4104 2012/04/12 22:00:09 AdlmActError=8 [An item is not found]
4104 2012/04/12 22:00:09 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
4104 2012/04/12 22:00:09 AdlmActError=18 [Argument to a function is bad]
2840 2012/04/12 22:00:10 Reason=Fatal error
2840 2012/04/12 22:00:10 ComputerName=OWNER-PC
2840 2012/04/12 22:00:10 OS=6.1.7601.Service Pack 1
2840 2012/04/12 22:00:10 File=AdlmIntSATSLicense.cpp,Line=416
2840 2012/04/12 22:00:10 VendorID=2 [ADLMACT]
2840 2012/04/12 22:00:10 VendorError=18 [Argument to a function is bad]
2840 2012/04/12 22:00:27 Reason=Fatal error
2840 2012/04/12 22:00:27 ComputerName=OWNER-PC
2840 2012/04/12 22:00:27 OS=6.1.7601.Service Pack 1
2840 2012/04/12 22:00:27 File=AdlmIntSATSLicense.cpp,Line=2164
2840 2012/04/12 22:00:27 AdlmIntError=17 [The license was not found]
420 2012/04/13 17:08:01 Reason=Fatal error
420 2012/04/13 17:08:01 ComputerName=OWNER-PC
420 2012/04/13 17:08:01 OS=6.1.7601.Service Pack 1
420 2012/04/13 17:08:01 File=AdlmFlxActTS.cpp,Line=611
420 2012/04/13 17:08:01 AdlmActError=8 [An item is not found]
420 2012/04/13 17:08:01 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
420 2012/04/13 17:08:01 AdlmActError=18 [Argument to a function is bad]
4072 2012/04/13 17:08:01 Reason=Fatal error
4072 2012/04/13 17:08:01 ComputerName=OWNER-PC
4072 2012/04/13 17:08:01 OS=6.1.7601.Service Pack 1
4072 2012/04/13 17:08:01 File=AdlmIntSATSLicense.cpp,Line=416
4072 2012/04/13 17:08:01 VendorID=2 [ADLMACT]
4072 2012/04/13 17:08:01 VendorError=18 [Argument to a function is bad]
2088 2012/04/13 17:24:41 Reason=Fatal error
2088 2012/04/13 17:24:41 ComputerName=OWNER-PC
2088 2012/04/13 17:24:41 OS=6.1.7601.Service Pack 1
2088 2012/04/13 17:24:41 File=AdlmFlxActTS.cpp,Line=611
2088 2012/04/13 17:24:41 AdlmActError=8 [An item is not found]
2088 2012/04/13 17:24:41 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
2088 2012/04/13 17:24:41 AdlmActError=18 [Argument to a function is bad]
5332 2012/04/13 17:24:41 Reason=Fatal error
5332 2012/04/13 17:24:41 ComputerName=OWNER-PC
5332 2012/04/13 17:24:41 OS=6.1.7601.Service Pack 1
5332 2012/04/13 17:24:41 File=AdlmIntSATSLicense.cpp,Line=416
5332 2012/04/13 17:24:41 VendorID=2 [ADLMACT]
5332 2012/04/13 17:24:41 VendorError=18 [Argument to a function is bad]
Hello i have the same problem with my AUTOCAD 2012, can you explain me a little better what did you do to solve the problem withe the Inventor 2010 flexnet license error, i think it will work for me too! but i dont understand very well what u are trying to explain... i have a windows 7 64 bits, hope u can help me! im trying to fix it for to longg already!! THANKSS A LOT!
