• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Inventor 2010 flexnet license error!
    990 Views, 15 Replies
    06-16-2009 09:18 AM
    In the common course of first activation, a liceseing screen screen will show before the main program.
    But I click the inventor icon on the desktop, nothing happens!
    I insert a system variable:FLEXLM_DIAGNOSTICS and valued it as 3
    I got the folloing msg:
    Checkout error returned from FLEXnet:No such feature exists.
    FLEX Feature: INVPRO_F_S
    License path:
    FLEXnet Licensing error: -5, 357
    I have uninstalled all the parts of inventor 2010 professional suits , cleaned all autodesk items in the registry
    and reinstall inventor 2010, but it didn't help!
    my computer is thinkpad x200
    and the system is xp x86 with 4G ddr3-1066 ram
    anybody can solve this problem?HELP! Edited by: perhaps on Jun 16, 2009 4:18 PM
    Please use plain text.
    *Dennis Jeffrey
    Re: Inventor 2010 flexnet license error!
    06-16-2009 09:47 AM in reply to: perhaps
    Did you configure LMTOOLS as using a service or a license
    file?
    Dennis Jeffrey, Autodesk Inventor Certified
    Expert
    Autodesk Manufacturing Implementation Certified
    Expert.
    Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
    AIP 2008 SP3,
    AIP 2009-SP1 PcCillin AV
    AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
    XP Pro SP3, Windows XP Silver Theme
    href="http://teknigroup.com">http://teknigroup.com
    06-16-2009 05:55 PM in reply to: perhaps
    yes, I also installed ansys and nastran in my computer.
    They are using LMTOOLS as license manager.
    But I don't find any license manager during installation of inventor.
    According to successful installation, I will input the activation code in the first time.
    but the license screen did'nt show.
    *Kevin Hu
    06-16-2009 06:35 PM in reply to: perhaps
    Did you install Inventor with Standalone
    license(default selection) or Network license(need to input server name when you
    configure Inventor)?
    if it is standalone, after you click the shortcut
    of Inventor, open task manager, can you see Inventor.exe process
    started?
    if it is network license, you have to install
    LMTools from Tools and Utility, you can find it on the first launch page after
    you start setup.exe.then get a network license from Autodesk and import
    LMTools.
    *Dennis Jeffrey
    06-16-2009 08:47 PM in reply to: perhaps
    To add to Kevin's reply. If you have a network version and you
    have FLEXLM version 10.8 or above, you should be able to add the Autodesk .lic
    file as a separate service on the same Flex server.
    If you need more assistance with netowork licensing
    of ANY Autodesk product, go to the autodesk.autocad.network discussion
    group.
    Expert
    Expert.
    AIP 2008 SP3,
    06-17-2009 02:19 AM in reply to: perhaps
    my installation is standalone.
    after click the shortcut, harddisk light will blink for about one minute,
    but NO inventor.exe process shows in task manager. Edited by: perhaps on Jun 17, 2009 9:21 AM
    *Dennis Jeffrey
    06-17-2009 04:42 AM in reply to: perhaps
    Did you install following these guidelines?
    Expert
    Expert.
    AIP 2008 SP3,
    06-17-2009 04:47 AM in reply to: perhaps
    sorry, I made a mistake:
    after click the shortcut, inventor.exe process will SHOW in task manager.
    then "flexible license manager" window will pop up and tell me flexnet licensing check out error
    seconds later a system warning sound "bang"
    and inventor.exe process will disappear.
    06-17-2009 04:55 AM in reply to: perhaps
    Disable all antivirus services
    is this really Critical?
    I'm using avast!
    and successfully installed inventor 2010 on win7 RC7127.
    it confuse me what's wrong with winxp
    *Dennis Jeffrey
    06-17-2009 05:11 AM in reply to: perhaps
    Yes it is critical. So is turning off th UAC. I would not have
    listed them if they were not critical steps.
    BTW, I run Avast! on my xp64 , and I always turn off all
    Avaste services before any install.
    Expert
    Expert.
    AIP 2008 SP3,
