• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Inventor 2010 - BOM Item No.
    482 Views, 2 Replies
    06-03-2010 04:38 AM
    How do I get to link the Item No. from the BOM to part text descriptions within the idw. ??
    Please use plain text.
    *Dennis Jeffrey
    Re: Inventor 2010 - BOM Item No.
    06-03-2010 04:49 AM in reply to: kand0
    Can you post an example of what you want? See this:
    http://teknigroup.com/support/Inventor/Howto.html
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Subscribe to the free "The Creative Inventor Magazine now available at:
    http://teknigroup.com/CI-Subscribe-Login.asp
    New Member
    06-03-2010 03:10 PM in reply to: kand0
    The attached is a part copy of a drawing showing an example of what I am after. In most cases when you assemble a component or a welment in the iam the order of the part number will not be in a prefered order which I want to have the BOM displayed in. As with common drafting practice the BOM is usually created after the assembly is complet in the prefered desplay order. With inventor this is an easy process to create the required order of materals and then re number the Item No.s in the BOM structure. However when I do the part detail I want to insert a part description automaticaly displaying the item No. which has been assigned by the user. However in the Text properties the Item No. does not appear in the properties in order it can be added as a text perameter. The only get arround I have found is to manually copy the Item No.s to an unuesed properties field ( in my case Stock Number eg "ITEM 3 - DETAIL") this manual process off cource may lead to errors. Edited by: kand0 on Jun 3, 2010 10:42 PM
