• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Inventor 2008 and Technical Illustrations
    213 Views, 17 Replies
    03-31-2008 09:07 AM
    Hi there, does anyone have information on how useful inventor 2008 is when it comes to making a technical illustration? and let me also know if there is any short coming in that aspect. This is because I am looking for a Dissertation topic and I want to base it on Technical illustrations using Autodesk inventor. Thank you
    Please use plain text.
    Re: Inventor 2008 and Technical Illustrations
    03-31-2008 09:33 AM in reply to: dwaynem213
    At what level is this dissertation intended?
    I think you are going to be hardpressed to fine enough information on Inventor for Technical Illustrations.
    Distinguished Contributor
    03-31-2008 09:44 AM in reply to: dwaynem213
    I was thinking the same thing. If this is a dissertation for a 1 semester CAD course then it might be a good topic. If it is a MS or PhD dissertation, then there is not enough info, or opportunities for research.
    *Hal Gwin
    03-31-2008 10:11 AM in reply to: dwaynem213
    There were a couple of classes at AU 2007 that might help you in your
    research. Send me an email direct and I will pass on the email
    addresses of the authors.
    Hal Gwin
    Mechanical Designer
    Caliper LifeSciences
    R2008 Pro SP2 D3D
    XP Pro SP2
    Dell Precision 650
    Dual 2.66 GHz Xeon
    3 GB DDR
    Quadro FX 3000
    nVidia 6.14.11.6262 w/registry update
    Dell UltraSharp 24" Widescreen LCD
    03-31-2008 11:17 AM in reply to: dwaynem213
    Thanks for the reply....The dissertation is for my Bsc in CAD. the dissertation is meant to try and find a solution or an alternative method to a CAD problem. so i think i might be able to work with inventor in this case. Any more information on this is highly welcome. Thanks
    03-31-2008 11:22 AM in reply to: dwaynem213
    thanks for the reply. Can you please let me know how to get your email adress. Thanks
    03-31-2008 11:47 AM in reply to: dwaynem213
    by a Technical Illustration, do you mean a drawing as part of a printed manual? Inventor is very good at producing technical illustrations. I think the biggest problem that has been addressed on this forum is integration with word processing programs. The problem there is having an easily updateable document that stays in sync with the design, has appropriate printing resolution, and can be labeled to make a list of illustrations for the document table of contents.
    In the "real" world, I don't know how much this is actually done compared to design documentation. We don't do any documentation outside Inventor, but for our needs there is relatively little writing compared to drawing and annotation.
    03-31-2008 12:36 PM in reply to: dwaynem213
    Thank you. I will look into the suggestion you put down. I am talking about an illustration such as the attached and looking at comparing methodologies on how best to create such within Inventor, a 2D software and an illustration package.
    03-31-2008 12:44 PM in reply to: dwaynem213
    ah, well Inventor cannot produce that image directly, but with a combination of Inventor Studio and Photoshop, you could make that image fairly easy (given that you already had a complete model of the motor ;-) )
    *Hal Gwin
    03-31-2008 03:38 PM in reply to: dwaynem213
    Should appear in the "from". It is hal.gwin@caliperls.com
    Hal Gwin
    Mechanical Designer
    R2008 Pro SP2 D3D
    XP Pro SP2
    Dell Precision 650
    Dual 2.66 GHz Xeon
    3 GB DDR
    Quadro FX 3000
