• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Invalid serial number
    360 Views, 7 Replies
    01-19-2013 12:48 PM
    I am getting the message of invalid serial number. I would like to speak to someone directly to help me solve this problem instead of flipping through self help information. Thanks
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Invalid serial number
    01-19-2013 01:47 PM in reply to: zachdixon0118
    Hi zachdixon0118,
    Visit the Installation & Licensing forum. Autodesk staff actively monitor that forum working to answer your installation and licensing questions.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Distinguished Contributor
    01-19-2013 02:42 PM in reply to: zachdixon0118
    Things to watch out for are, entering a network serial number into a standalone install. There's also accidentally using the wrong year version or wrong product version, like using an ultimate serial number for a premium install.
    New Member
    01-19-2013 07:20 PM in reply to: donovan.cox
    The network/standalone problem might be it. My thing is that the company I work for has Inventor on all of its computers and they had it installed before I started employment. They know less about the installation process than I do but I would assume that they ran it as a network. For some reason I probably installed it as a standalone instead. Is their any way to change this without reinstalling?
    Distinguished Mentor
    01-20-2013 05:56 AM in reply to: zachdixon0118
    Only way to fix is to reinstall.
    John Retzlaff
    ampster
    01-21-2013 05:57 AM in reply to: zachdixon0118
    good answers so far to your question but just in case you're not aware, this isn't the place to expect to communicate directly with Autodesk.  You're question seems to indicate that was what you were hoping for.
    Mason-Paul
    01-21-2013 06:28 AM in reply to: ampster
    There is a separate board for installation problems here
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    I believe that this board IS MONITORED by Autodesk.
    Maybe the this board's moderator can move/copy this question over
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    philip.s
    01-21-2013 01:53 PM in reply to: Mason-Paul
    Typically your best bet in this situation, outside of checking to make sure you're using the appropriate serial number and product key (not previous versions) and installing as the right deployment (standalone vs.network), would be to contact our License Assitance team for direct support.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
