• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    karthur1
    Invalid Reference to segment object used
    211 Views, 4 Replies
    12-10-2012 07:30 AM
    I derived in a part and I am trying to use a sketch from it in my new part.
    I am trying to revolve my sketch and when I do I get this error.
    I am using a English version, and I cant read chinese at all.  Design doctor shows no errors, but this will not revolve. Tried Extruding and get the same error.  When I try to revolve, it shows a preview of my part correctly, but when I click apply in the revolve dialog, that is when I get this error.
    The files are attached and here is a video of my steps. In the zip file, the -M8.ipt needs the EOF marker moved all the way to the bottom.
    Kirk A.
    Windows 7 x64 -12 GB Ram
    Intel i7-930 @ 3.60ghz
    nVidia GTS 250 -1GB (Driver 301.42)
    INV Pro R2013, SP1.1
    Vault Basic 2013
    Please use plain text.
    Distinguished Contributor
    Re: Invalid Reference to segment object used
    12-11-2012 02:50 AM in reply to: karthur1
    I am also getting this error sometimes..
    It occurs mainly when trying to insert a custom content center member through the API. The weird thing is that it doesn't occur everytime. First I thought it had something to do with the Check In command of the Vault Addin, because turning off DWF creation at check in time solved the problem - or at least I thought. It came back after a while, so probably nothing to do with the Check in command as well..
    Could somebody from Autodesk, please point out what could cause this Chinese error on a English version of Inventor? How can I get rid of this error? Any hotfixes?
    Pim Saarloos
    Member
    12-11-2012 08:12 AM in reply to: karthur1
    I'm getting the same type of errors that Pim describes.
    Anybody got a clue?
    Product Support
    12-12-2012 01:50 PM in reply to: karthur1
    Not going to admit I have a clue but can state this error is too generic to say that all possible instances where you would see this pop up could be related. Kirk's issue seems to be at the sketch level. see attached. Pim’s might be at the content center level but possible this CC part might have blocks in it? Depending on IDCL or MDF format I would run library through the update wizard located in project file, select the “Configure CC Libraries button above the “Done” button if you see a lightning bolt. Kirk for your file I will log it to development.
    Don
    Active Member
    kylegoltsch
    12-17-2012 10:55 AM in reply to: karthur1
    I am also getting this message.  I have talked to Autodesk Technical support and they have sent it to development.  I am now been rebuilding my assembly everyday since 12/6/2012 and have no answer.  I just have to keep re doing the same work everyday (if I was in a joking mood I would reference Groundhogs day with Bill Murray).
    My customer wanted a final design on 12/12.  He is still (impatiently) waiting.
