• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Internet access is required to access the Help
    256 Views, 4 Replies
    04-26-2012 10:37 AM
    Just loaded 2013. Of course right away I get an error. "Internet access is required to access the Help" Well as you can see I have internet access.
    Any suggestions? (I mean besides reloading 2012)
    Mike Eck
    Senior Designer/ CAD Programmer
    Howden North America
    Using Inventor 2013
    Please use plain text.
    Distinguished Contributor
    Re: Internet access is required to access the Help
    04-26-2012 10:46 AM in reply to: meck
    Is what you want here?
    c:\Program Files\Autodesk\Inventor 2013\Help_Lite\
    04-26-2012 10:52 AM in reply to: dick_upton
    I'm confused!
    If you are asking me if there is a folder called Help_Lite under my Inventor 2013 folder the answer is no.
    Otherwise what I want is to be able to access the help files online.
    Mike Eck
    Using Inventor 2013
    *Expert Elite*
    Curtis_Waguespack
    04-26-2012 11:35 AM in reply to: meck
    Hi meck,
    I'm not sure what the problem is, but there is some information on setting it up to use the local help at this link (in case you don't get it sorted):
    http://inventortrenches.blogspot.com/2011/04/where-are-inventor-2012-tutorial-and.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    04-26-2012 11:57 AM in reply to: Curtis_Waguespack
    Thanks for the response.
    I would rather have it online, but if it becomes a real issue I will download it
    Mike Eck
    Using Inventor 2013
