• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *BP
    Internal error in persistence operation - can't save Assembly
    253 Views, 4 Replies
    11-11-2002 01:15 AM
    Can anyone tell me if there is a fix for this problem?
    Running IV6, WinNT5 sp6a
    Getting the following Error message while trying to save an assembly (that
    was previously savable).
    We have tried to remove the part that was added right before the problem
    began.
    Bill
    [WARNING] Problems encountered while saving the document.
    [r:\core\Fw\Main\FWxSceneDoc.cpp, line 1431]
    [ERROR] Error(s) detected while writing segment AmDcSegment in database
    C:\WINNT\Profiles\cad7_nt.000\Desktop\temp\Final Assembly.iam
    [r:\core\RSe\segment\segStream.cpp, line 242]
    [ERROR] Error detected while saving object of type RDxOccurrence
    [r:\core\RSe\meta\meta.cpp, line 967]
    [ERROR] Internal error in persistence operation (Segment loading
    is not supported within other persistence operations)
    [ERROR] The database in C:\WINNT\Profiles\cad7_nt.000\Desktop\temp\Final
    Assembly.iam could not be saved
    [r:\core\RSe\database\databaseC.cpp, line 1195]
    Please use plain text.
    *BP
    Re: Internal error in persistence operation - can't save Assembly
    11-11-2002 01:16 AM in reply to: *BP
    began.
    Bill
    Valued Contributor
    11-11-2002 06:37 AM in reply to: *BP
    I'm getting the same error... Anyone have any ideas? Bueler... Bueler... Bueler...
    [ERROR] Error(s) detected while writing segment AmDcSegment in database G:\1INVENTOR\Parts & Assemblies\E-Size\EX\EX20046.iam [r:\core\RSe\segment\segStream.cpp, line 242]
    [ERROR] Error detected while saving object of type RDxOccurrence [r:\core\RSe\meta\meta.cpp, line 967]
    [ERROR] Internal error in persistence operation (Segment loading is not supported within other persistence operations)
    [ERROR] The database in G:\1INVENTOR\Parts & Assemblies\E-Size\EX\EX20046.iam could not be saved [r:\core\RSe\database\databaseC.cpp, line 1195]
    *Rennick, Alan
    Re:
    11-11-2002 10:04 AM in reply to: *BP
    Tools>Rebuild All on the assembly, any
    subassemblies, and any parents of derived parts in your assemblies.  (Don't
    try to save until you've done it to all of 'em!).
    The word from Adesk (via my VAR) is that SP1 will
    fix it, but this is the workaround for the time being...
    Cheers!  Alan
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I'm
    G:\1INVENTOR\Parts & Assemblies\E-Size\EX\EX20046.iam <RSeRes(622)>
    RDxOccurrence <RSeRes(1408)> [r:\core\RSe\meta\meta.cpp, line 967]
    persistence operations) <RSeRes(623)>
    Assemblies\E-Size\EX\EX20046.iam could not be saved <RSeRes(202)>
    Valued Contributor
    Re:
    11-11-2002 09:36 PM in reply to: *BP
    Thanks, I'll give it a try and post the results...
    Rick
