• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Installed INV 2013 - very slow.
    359 Views, 13 Replies
    12-04-2012 11:25 AM
    We just switched to Inventor 2013.
    What in the set up could be causing poor graphic performance (chugging, parts dissapearing when rotating model) - we have few stations with the same parameters, some perform well some as above?
    Please use plain text.
    *Expert Elite*
    cbenner
    Re: Installed INV 2013 - very slow.
    12-04-2012 11:42 AM in reply to: Infoseeker
    Please post a sampling of the system specs of the systems that are having troubles.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Member
    12-12-2012 08:08 AM in reply to: Infoseeker
    I am having a similar problem. IV 2012 works fine. IV 2013 is essentially unusable. Pan and orbit take minutes to update. Features seem to work ok. Adding a fillet or hole is about the same as 2012. The view cube also takes almost a minute to update a view, even the home view.
    I would like to start using 2013 and am reluctant to remove 2012 since it is working and 2013 is not. My system meets requirements for both:
    System
     ManufacturerGateway
     ModelDX4300
     Total amount of system memory8.00 GB RAM
     System type64-bit operating system
     Number of processor cores4
    Storage
     Total size of hard disk(s)2011 GB
     Disk partition (C)393 GB Free (914 GB Total)
     Media drive (D)CD/DVD
     Disk partition (E)2 GB Free (124 GB Total)
     Disk partition (F)54 GB Free (58 GB Total)
     Disk partition (X)393 GB Free (914 GB Total)
    Graphics
     Display adapter typeATI Radeon HD 4600 Series
     Total available graphics memory4735 MB
     Dedicated graphics memory1024 MB
     Dedicated system memory0 MB
     Shared system memory3711 MB
     Display adapter driver version8.970.100.3000
     Secondary monitor resolution1920x1080
     Primary monitor resolution1280x1024
     DirectX versionDirectX 10
    Network
     Network AdapterMarvell Yukon 88E8071 PCI-E Gigabit Ethernet Controller
     Network AdapterRealtek 8185 Extensible 802.11b/g Wireless Device
    The forums seem like a good place to start, but I have seen that many others are having a similar issue and I see no resolution so far.
    Anyone have thoughts on this?
    Distinguished Mentor
    12-12-2012 08:15 AM in reply to: bradleydawson
    Did you install SP1.1 and update 1 for SP1.1?
    John Retzlaff
    Member
    12-12-2012 08:28 AM in reply to: john.retzlaff
    Are these service packs for Autodesk or Windows? How do I check for these?
    I just uninstalled IV2013 and downloaded and installed it again. It should be the latest available.
    12-12-2012 08:30 AM in reply to: bradleydawson
    *Expert Elite*
    sam_m
    12-12-2012 08:46 AM in reply to: bradleydawson
    Bradley, you could well be hitting the limits of that pc tbh.
    looking for DX4300 I get this spec:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16883113104
    The Radeon 4650
    http://www.videocardbenchmark.net/high_end_gpus.html (benchmark)
    is v low powered compared to what Inventor really needs (and can only guess the 4600 is even worse).
    No idea why your spec say's you've allocated 3711MB ram to be shared with the graphics card - personally would suggest nocking that down to leave as much of the 8gb left to be system ram and have the gpu just use its on-board memory.  I would also try updating the drivers - the one listes is about 6 months old.  might also try disabling the 2nd monitor to see if it helps at all (give as much processing power to 1 screen and Inventor instead of trying to deal with displaying info on 2 screens).
    AMD Phenom II X4 810(2.6GHz)
    http://www.cpubenchmark.net/singleThread.html (benchmark for single-threaded application)
    is pretty awful too, compared to most modern cpus.
    at the end of the day, it's a 3-4 year old system spec that was only "average" speed when new.  Sorry to say it, but could well be the case of needing new hardware.
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
    Member
    12-12-2012 10:21 AM in reply to: sam_m
    The problems are with extremely simple models, like an extruded rectangle. The reqs for 2012 are not much different from 2013, but if you're right, I will stay with 2012 until enough issues force me to update my system.
    In the meantime, I am going to the install forum to find out why double clicking the msp files doesn't work.
    *Expert Elite*
    blair
    12-12-2012 04:48 PM in reply to: bradleydawson
    DirectX10 is not helping as well. You probably have a slow hard-drive as well.
    Open your task manager and look for any programs/services that are using a lot of resources. Having items running in the back-ground and a nice picture on your moniter doesn't help either.
    You can also turn off all the "bling" on your system:
    Start>Control Panel>System Properties>Advanced>Performance>Settings>Adjust for best performance
    Defrag your system and clean all temp files / directories.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Contributor
    jonathanruffray
    Re : Installed INV 2013 - very slow.
    12-17-2012 09:37 AM in reply to: Infoseeker
    Hello all,
    it seems we are some users in this forum to have Inventor 2013 which become painfully slow even to extrude a simple cube...
    Refer to this : http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-really-slow/m-p/3709580#M454755
    Maybe our PC spec are not the best but what I can't understand is:
    " Why Inventor 2012 was running well and Inventor 2013 is painfully slow... Something is wrong.. How could be a computer be at ground with only a simple function and only one version more.!! :smileysad: "
    Something other, here in my office we are 6 users, only 2 ( including me:smileymad:)have this slowdown problem with same PC specs, same hotfix, ...
    Cheers,
    Autodesk Product Design Suite Ultimate 2013
    Win 7 Pro 64 bits SP1
    Bi-Xeon E5520 (2x Quad-core @2.27GHz)
    Quadro Fx 1800 768Mo GDDR3
    6Go Ram DDR3 667MHz ECC
