• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Gary Cross \( IV10 SP2\)
    Install error Failure occurred when attaching InventorStandardContent library
    96 Views, 5 Replies
    01-12-2006 02:11 PM
    Can anyone tell if this is a problem & how to resolve?
    I'm getting following error upon re-install of IV10 after just uninstalling
    "Process return code 2: Failure occurred when attaching
    Please see
    C:smileyvery-happy:ocument...\Admin...\Locals\Temp\AttachLibrary_exe.InventorStandardContent
    .log"
    I can't find any InventorStandardContent.log file on my computer. I can
    complete the install but I don't want any surprises later.
    All was well with my first install of vanilla IV10. The error first happened
    during online SP1 install (not from a file) after I interrupted the SP1
    install & clicked to install the SP1 again.
    Gary
    Please use plain text.
    Re: Install error Failure occurred when attaching InventorStandardContent library
    01-12-2006 05:09 PM in reply to: *Gary Cross \( IV10 SP2\)
    Well, I went ahead & installed all 3 SP's anyway.
    Guess I'll find out if there will be any issues with using the content
    library. Sure would like to know if that error was benign though.
    Gary
    *Jeff Pek \(Autodesk\)
    01-12-2006 06:14 PM in reply to: *Gary Cross \( IV10 SP2\)
    If the uninstall completed successfully, then a reinstall should have worked
    without the error.
    My recommendation is to see if the content is still available after
    installing the SPs. The logs should be available at %TEMP%.
    Jeff
    "Gary Cross ( IV10 SP2)" wrote in message
    news:5058007@discussion.autodesk.com...
    Gary
    01-12-2006 09:43 PM in reply to: *Gary Cross \( IV10 SP2\)
    Jeff,
    There's no sign of content in temp directory. What should I check to see if
    the install is ok? I assume the message was just related to the Content
    Library, correct?
    Gary
    *John Elliott - Autodesk
    01-30-2006 09:07 AM in reply to: *Gary Cross \( IV10 SP2\)
    Uninstall MS SQL - Inventor content, then go into :\Program files\
    find the MS SQL directory and delete the Inventor content database.
    news:5058114@discussion.autodesk.com...
    Jeff,
    Library, correct?
    Gary
    Distinguished Contributor
    06-14-2006 07:28 PM in reply to: *Gary Cross \( IV10 SP2\)
    Could you tell me if you were able to resolve the problem "Re: Install error Failure occurred when attaching InventorStandardContent library" and how?
    Thanks.
