• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Inserting a Part many times in an assembly
    131 Views, 3 Replies
    02-03-2013 11:29 AM
    If I nead to insert a Part a many times in an assembly... let's say fifty times.
    The only way I know is to copy past fifty times (then I place them with the constraints neaded).
    The rectangle or cicular array can't be used since they a realy in different places.
    But is there a fastest way to insert the Part fifty times in the assembly, instead of copy paste?
    Thanks in advance!
    Sophie
    Please use plain text.
    Valued Contributor
    Re: Inserting a Part many times in an assembly
    02-03-2013 12:25 PM in reply to: SophieSmith
    You can use iMates for this if there is no pattern.
    If you need help on that let me know.
    Rob.
    Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
    Software in use: Inventor 2013, SolidWorks 2011
    Also experience with: Solid Edge untill ST4,
    rhasell
    02-03-2013 05:02 PM in reply to: VdVeek
    If there is any sort of pattern, even 50% of the items, try use "Feature Pattern"
    The part pattern features are more powerful and versatile, than the assembly pattern features.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Employee
    02-03-2013 07:21 PM in reply to: SophieSmith
    Hi Sophie,
    If you just want to insert the part a many times in one assembly, and don't care much the position of placement. You could use iLogic rule or VBA Macro to make it faster. If you also care much about the position of placement, maybe you could consider the iMate.
    River Cai
    Quality Assurance Team
