• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Increasing Edge display weights?
    241 Views, 4 Replies
    05-20-2012 12:23 AM
    Is there a way to increase the edge weights/color of a part/assembly?
    To see what I mean I attached a screenshot of a simple cylinder with the view set to shading with edges. Yeah the edges are there, but I'd really like them to stand out more.
    Please use plain text.
    *Expert Elite*
    karthur1
    Re: Increasing Edge display weights?
    05-20-2012 12:46 AM in reply to: helloworld922
    What color scheme are you running?  you could try changing to a different one and see if that help you, but I think thats about it.
    Look in Tools>Application options, Display tab. Click on the Settings button here.  In the Display Appearance window, you can change the edges color under "Model Edges".
    Member
    05-20-2012 08:06 AM in reply to: karthur1
    hmm, ok. I changed the color to black and it kind of helped, but it's still not as good as I would like it to be.
    *Expert Elite*
    karthur1
    05-20-2012 10:26 AM in reply to: helloworld922
    In the model edges, select one color, then change the color to something other than black.... try yellow.
    Does that help?  No way that I know to make the edges "thicker".
    Member
    05-20-2012 01:36 PM in reply to: karthur1
    I tried yellow, red, and a few others and to me black stands out the most. Too bad I can't increase the line display thickness :smileysad: I like the thickness it displays sketches with.
