• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    In a Sheet Metal pressure cooker
    51 Views, 2 Replies
    11-03-2002 11:13 PM
    I am a seasoned AutoCad 2002 designer but new to the Inventor world. I have taken the 5.3 fundamentals course and am cramming furiously with hands on practice while waiting for the next available advanced course in my area (end of Dec). I am the senior designer in our office and typically work on the hotter more complex jobs for my boss. I find myself in the all so familiar pressure cooker trying to utilize Inventor and am struggling with a few things that are probably elementary in nature.
    I am trying to construct a complex sheet metal part that has a 4-pointed star like shape. Each leg of the star is identical and made up of various faces, folds, and extrusions. There are coined areas where the metal is thinned this is why I extruded and “cut” the leg as needed. So I found myself using both “Sheet Metal” toolbar functions and “Features” toolbar functions to shape, bend, and whittle out the final leg shape. Now I’m left with a one legged part and have ran into some roadblocks that prevent me from completing the rest of the part.
    1) How do I create a circular pattern to get four identical legs? I get a message that says “set contains objects that cannot be patterned” what does that mean? Is it because I combined sheet metal and standard functions?
    2) I also tried to make an assembly by placing four instances of the legs, but that prevents me from being able to further cut and shape the complete assembly as if it were one part!
    I’m sure this is a beginners dilemma and more of a planning or methodology issue than a software issue.
    Any help is greatly appreciated.
    Thanks, Tom…
    Please use plain text.
    *Keller, Kent
    Re: In a Sheet Metal pressure cooker
    11-04-2002 12:36 AM in reply to: tmalinski
    Many sheetmetal parts aren't allowed to be patterned.
    Try making your assembly and then derive it into a new IPT file. You should be able to
    continue your design there, and it will stay parametric with the original leg.
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "tmalinski" wrote in message news:f11f625.-1@WebX.maYIadrTaRb...
    says "set contains objects that cannot be patterned" what does that mean? Is it because I
    one part!
    > I'm sure this is a beginners dilemma and more of a planning or methodology issue than a
    software issue.
    > Thanks, Tom.
    *Jeffrey, Dennis
    11-04-2002 01:43 AM in reply to: tmalinski
    1. You cannot pattern sheet metal features at this time.
    2. I would construct the part as a sheet metal part, add chamfers,
    etc., then add fold lines for each point. did a similar part last
    week...
    Dennis
    > Thanks, Tom…
    Dennis Jeffrey
    CAD Associates - Fort Wayne
    Autodesk ASC
    (260-432-9695 x 221
