• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Impossible sheet
    212 Views, 3 Replies
    01-01-2013 08:09 AM
    Hi
    Here are four similar files (very tiny), but I dont understand why the results are different. Can someone explain the curio as in Annex?  I can not do sheet in file no.2. :smileysurprised:
    Please, help me.
    Thank you in Advance
    _______________________________________________________
    Windows7 64b; GIGABYTE EX58-UD5; Intel Core i7 920 (2.66GHz)
    DDR3 3x2GB Kingston, HD ST 750GB+320GB
    NVIDIA Quadro FX1800 (1680x1050) + SpacePilot PRO
    Please use plain text.
    Active Contributor
    Impossible sheet - continued
    01-01-2013 08:17 AM in reply to: malenki
    Yet another file (attached) to my previous topic.
    Regards.
    Valued Mentor
    Re: Impossible sheet
    01-01-2013 11:07 AM in reply to: malenki
    If you take the file (4) you attached in your other post thread, lofting the complete profile, then overlay the imposible sheet (2) from this post you will see that in order to achive the upper tight radius shape the fold lines need to terminate beyond the extent of the lower sketch you are trying to use in file (2). I assume this is why you can not get it to work as the folds would need to terminate along the vertical edges as well as the uper and lower sketch.
    Can you not use file (4) as a master file and derive / split the sections out as needed ?
    Regards
    Martin
    PDSU 2014 RTM
    Windows 7 64bit, Office 2007 Pro
    Intel i7 980x, 24 Gb DDR3 RAM
    Geforce 580GTX Graphics (Diver 310.70)
    256GB SSD OS, 80GB SSD working folder
    Space Pilot
    Active Contributor
    01-01-2013 01:49 PM in reply to: Martin_Goodland
    Hi, thanks devoted time
    Naturally, I came up with this idea in the meantime. However, it is only prosthesis...
    By the way...
    I cannot pull the sheet by "lofted flanges" (and other metods) from spline profiles. It seems to me that it should be possible. In previous versions of Inventor (before 2012) it was possible to unfold a solid (like sheet) created in the part module after transfer to the sheet module. Currently (2012/2013) this property has been very limited. Do not you have such experience?
    Regards
