Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Importing step files into assemblies in 2013
- Highlight
- Email to a Friend
I am trying to import a step assembly file in 2013.
Under the options settings I no longer have or see the ability to,
(Import Multiple Solids Parts as Assembly) This was an option to check.
This seems to be a big issue as we always import the assemblies, then ground them.
And this gives us the option of moving or deleting certain components, as well as opening individual
components in their own part environment.
Please advise?
Thank you
Mark E.
Re: Importing step files into assemblies in 2013
- Highlight
- Email to a Friend
Attach the *.stp file here.
It should recognize the file as an assembly or you can always push the parts and assembly out after opening.
Inventor Professional 2014 Edu 64-bit
- Highlight
- Email to a Friend
I believe there may be a bug in the software.
It is not recognizing that's its an assembly file.
I exported an assembly file as a step, and then reopened it
and it opened fine with all the components in the model tree as separate parts.
I believe it worked because it was originally saved in Inventor.
My problem now is, which I never had before is that it is not recognizing
the file as an assembly and it is bringing in all the components a base features.
Thes are propietary files which I cannot share, but I know they are created in
the unigraphics modeling package as well as some proe.
Mark E.
- Highlight
- Email to a Friend
Post a screen shot of your import options as below.
- Highlight
- Email to a Friend
I have tried every available option and combination of options
as you show in the import options screenshot. After a little more digging through trial and error
we have conclude,(we believe) that the stp translator has a bug or is corrupted
in some fashion. We then tried to import a few parasolid assemblies, and they opened fine.
That is why we believe the translator software is not working right.
The other wrench in the works is, that it is not working on at least 4 workstations.
We are wondering at this point what to do. Software reload?
Thank you,
Mark E.
- Highlight
- Email to a Friend
I've got the same problem, and it only happened under 2013.
Attached is a sample STEP file that exhibits this behavior.
___________________________________________________________
Product Design Suite Ultimate 2013
Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
- Highlight
- Email to a Friend
Works fine here with the default settings. You may want to check with who supplied the file how they exported it.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 320.18
SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
- Highlight
- Email to a Friend
Blair & anyone else,
You say it works fine, and I disagree with you.
I can open any assembly (STP.) and get the same result as you.
The problem is, the file you show now is a single part file.
Note the top of your model tree, that is not an assembly icon, it is a part/surface icon
It should be an assembly icon. Try to right click on any one of those base features and open it.
It should open in a new window. You won't even have the option of opening it. When you expand
the model tree (solid bodies) and try to open up one of the base models, it takes you into the Fusion software.
In all previous versions, We had a checkbox in the Step import option that stated,
(Import Multiple Solid Parts as Assembly) It is no longer there in 20013.
If it is not needed there must be another solution to this, or I believe Autodesk dropped the ball here.
Frustrated and still hoping for a solution,
Mark E.
- Highlight
- Email to a Friend
I have added an attachment from old version of inventor, which clearly shows
the checkbox / option which has been omitted in the 2013 version.
Thank You,
Mark E.
- Highlight
- Email to a Friend
Are you sure that the step is an assembly and not a multi-body?
I just created a step froma an iam and it re-imported as an assembly.
