• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    john
    Importing ACAD sketches into Inventor 2012
    965 Views, 25 Replies
    11-10-2011 03:42 PM
    I am having difficulty importing ACAD sketches into Inventor 2012. I tried the import command at file open, the import command within a sketch, and just copying and pasting from ACAD 2012 and the lines are condensed into a single point. Is this a graphics card issue? I did not have this problem on 2010 (I am using 2010 temporarily for importing as a workaround).
    :robotsad:
    ***************graphics info**************************
    This Direct3D graphics driver is Microsoft WHQL certified
    Graphics Hardware Description:
    NVIDIA GeForce 8800 GTX
    AIRViz Device Manager \ VirtualDeviceDx11
    Feature Level 4_1
    Performance Mode
    Hardware Renderer
    Graphics driver file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is version 8.17.12.8562
    Current optimization settings are not known
    The display is using 32-bit color
    Inventor Version:
    Build: 190, Release: 2012 SP1 - Date: Mon 08/08/2011
    64-Bit Edition - 8192.00 GB
    Loaded Inventor Add-Ins:
    Inventor Fusion Change Manager
    Fusion Freeform Edit Launcher
    Inventor Studio
    Design Accelerator
    Frame Generator
    BIM Exchange
    Drag & Drop Interoperability
    System Information:
    Operating System:         64-bit Microsoft Windows 7 Professional  (Build 7601) Service Pack 1
    Language:             English
    System Manufacturer:         empty
    System Model:             empty
    BIOS:                 BIOS Date: 12/29/06 13:54:57 Ver: 08.00.14
    Processor:             Dual-Core AMD Opteron(tm) Processor 2220 (2 processors, 4 cores)
    System Memory:             15.999 GB RAM
    Graphics Device Information:
    Renderer:             HAL
    Manufacturer:             NVIDIA
    Chip Type:             GeForce 8800 GTX
    DAC Type:             Integrated RAMDAC
    Graphics HW Memory:         768 MB
    Display Mode:             1600 x 1200 (32 bit) (60 Hz)
    Graphics driver file:         nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver file version:         8.17.12.8562
    Driver Date:             15 October 2011 0:00:00 UTC (Coordinated Universal Time)
    Please use plain text.
    *Expert Elite*
    Re: Importing ACAD sketches into Inventor 2012
    11-10-2011 03:45 PM in reply to: john
    Attach a sample dwg file here.
    What options do you have set on Import?
    Active Member
    john
    11-11-2011 09:18 AM in reply to: JDMather
    Here are screen shots of the import settings:
    *Expert Elite*
    11-11-2011 09:55 AM in reply to: john
    Well, I just verified that I can in fact Import your dwg sketch, so now how to find the problem on your machine?
    Distinguished Mentor
    11-11-2011 10:10 AM in reply to: john
    One possibility:
    Make sure that template files "standard.idw" actually exists or change the destination template to one that you use
    Shooting in the dark!
    Active Member
    john
    11-17-2011 02:25 PM in reply to: rdyson
    Thanks rdyson. I double checked and it looks like my files were embedded in the bowels of "My Documents". I reinstalled Inventor so the files were in the correct location. However, I still have the same problem with importing.
    Product Support
    emily.xu
    12-04-2011 10:10 PM in reply to: john
    I can also import the .dwg file perfectly.Maybe something wrong with your profile or program.Would you please try to use another user to login your machine and test then?
    Emily Xu
    AutodeskCare | Product Support
    Autodesk, Inc.
    Active Member
    john
    12-06-2011 10:16 AM in reply to: emily.xu
    I logged in as a new user, but still the same result.
    Active Contributor
    12-06-2011 11:09 AM in reply to: john
    Have you tried a zoom all after you import? Mine usually tends to be way off of the origin when imported.
    Donald L.
    Inventor Product Design Suite Premium 2013 SP1.1
    Windows 7 Professional - 64 bit
    HP h8-1380t - i7-3820 @ 3.6 GHz
    10 Gb
    AMD Radeon HD7950 3Gb
    Active Contributor
    12-06-2011 11:37 AM in reply to: drlamb
    Also if you leave it set to mm instead of detected units it is going to be really small. A little over an eighth of an inch
    Donald L.
    10 Gb
