• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    MechEng_1
    Re: Import STYXML files to Inventor 2013 materials library
    01-11-2013 12:54 AM in reply to: chrismitchell01
    Hi Chris,
    Thanks for the reply, I have attached a few screenshots showing my workflow. I opened the one part file and carried all steps out within that one file.
    The other thing i have noticed that if i pick the colour from the drop down box at the top, the colour is very bright with no shadows etc. I saw above that you need to change the diffuse values to 0,0,1 but they are already set at that.
    Thanks again,
    Mike
    Please use plain text.
    Employee
    01-11-2013 03:06 PM in reply to: MechEng_1
    Hi Mike,
    You're doing the right things there; I don't know what's going wrong though - I just imported the same styxml file attached here to a new part file - see attached.
    If you open this file do you see the RAL appearances on both the drop down & in the appearance browser ?
    I'm using 2013 SP1.1 update1.
    Chris
    Chris Mitchell
    Inventor Quality Assurance Team
    Autodesk, Inc.
    MechEng_1
    01-14-2013 12:32 AM in reply to: chrismitchell01
    Hi Chris,
    I tried saving your file and opening it and i had exactly the same problem, it shows in the dropdown but not in the appearance browser. This is driving me crazy!!
    Thanks for the help.
    Mike
    MechEng_1
    01-14-2013 02:18 AM in reply to: MechEng_1
    Chris,
    Thanks again, i think i may have solved it. I noticed that i had the design data folder referencing a folder within my project instead of the default location. Once i had changed that back to the default it seems to have fixed itself. the ral colours now appear in the top section of the appearance browser.
    Mike
    Employee
    01-14-2013 04:44 PM in reply to: MechEng_1
    Ok Thanks for confirming, Mike.
    I suspect that the Design Data folder you were previously pointing to didn't have a complete set of files in it if it was from a prior release.
    -Chris
    Chris Mitchell
    Autodesk, Inc.
