Hi
I'm having an error with Ilogic parameters (see the attachments).
I just wanna change the border and the title blocks with Ilogic. This should be simple. Isn't this?
Helder Martins
Hi helmartins,
It's difficult to know what the problem might be with the information provided, but here are a couple of links that might help you get it sorted:
http://inventortrenches.blogspot.com/2011/05/use-ilogic-to-change-sheet-orientation.html
http://inventor-tales.blogspot.com/2010/11/drawing-conclusions-on-formatting.html
I hope this helps.
Curtis
this is my code works great you may have to take out the style change
trigger=iTrigger0 Dim drawingDoc as DrawingDocument = ThisDoc.Document Dim stylesMan As DrawingStylesManager = drawingDoc.StylesManager Trace.WriteLine(" --- Active drawing standard = " & stylesMan.ActiveStandardStyle.Name ) 'Pick Sheet Size Sheet_Size= InputListBox("Select Sheet Size", MultiValue.List("Sheet_Size"), Sheet_Size, Title := "Sheet Size", ListName := "Choose Sheet Size") 'A size If Sheet_Size = "A (8 1/2 X 11)" Then ActiveSheet.ChangeSize("A", MoveBorderItems := True) ActiveSheet.TitleBlock = "Uni Pak A" ActiveSheet.Border = "Uni Pak A" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak A") 'B size ElseIf Sheet_Size = "B (11 X 17)" Then ActiveSheet.ChangeSize("B", MoveBorderItems := True) ActiveSheet.TitleBlock = "Uni Pak B" ActiveSheet.Border = "Uni Pak B" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak B") 'C size ElseIf Sheet_Size = "C (17 X 22)" Then ActiveSheet.ChangeSize("C", MoveBorderItems := True) ActiveSheet.TitleBlock = "Uni Pak C" ActiveSheet.Border = "Uni Pak C" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak C, D") 'D size ElseIf Sheet_Size = "D (22 X 34)" Then ActiveSheet.ChangeSize("D", MoveBorderItems := True) ActiveSheet.TitleBlock = "Uni Pak D" ActiveSheet.Border = "Uni Pak D" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak C, D") 'E size ElseIf Sheet_Size = "E (34 X 44)" Then ActiveSheet.ChangeSize("E", MoveBorderItems := True) ActiveSheet.TitleBlock = "Uni Pak E" ActiveSheet.Border = "Uni Pak E" stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("Uni Pak E") End If Trace.WriteLine(" --- Active drawing standard = " & stylesMan.ActiveStandardStyle.Name ) 'update all InventorVb.DocumentUpdate() 'zoom all ThisApplication.ActiveView.Fit
