• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    dclunie
    Ilogic Rule to change custom iproperty
    335 Views, 1 Replies
    12-11-2012 12:54 PM
    Hi
    I am after help on writing part of rule for ilogic,i need the rule to fill out a custom property with information for me
    I have a part that has 2 parameters
    1. parameter 1 = Frontplanangle
    2. parameter 2 = Endplanangle
    Custom property
    iProperties.Value("Custom", "DESC2") =
    I need the rule to examine both parameters and if both angles = 0 then DESC2 = ""
    And if any parameter >0 then
    iProperties.Value("Custom", "DESC2") = bevel/
    Regards
    Dave
    Please use plain text.
    Curtis_Waguespack
    Re: Ilogic Rule to change custom iproperty
    12-11-2012 01:17 PM in reply to: dclunie
    Hi dclunie,
    Something along these lines should work:
    If Frontplanangle = 0 And Endplanangle = 0 Then
    iProperties.Value("Custom", "DESC2") = ""
    ElseIf Frontplanangle > 0 Or Endplanangle > 0
    iProperties.Value("Custom", "DESC2") ="bevel/"
    End If
    MessageBox.Show("DESC2 = " & iProperties.Value("Custom", "DESC2"), "iLogic")
     I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
