• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    Ilogic - Make drawing view shaded.
    241 Views, 6 Replies
    01-22-2013 02:03 AM
    Is there a line of code that will look at a drawing view and turn shading on?
    I have tried
    ActiveSheet.View("VIEW1").View.Shaded = True
    but it didn't work :smileysad:
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    Please use plain text.
    Valued Contributor
    Re: Ilogic - Make drawing view shaded.
    01-22-2013 03:22 AM in reply to: waynehelley
    There was an older post here: http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-code-for-Visual-styles-Shaded-w...
    Hope that helps you.
    Rob.
    Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
    Software in use: Inventor 2013, SolidWorks 2011
    Also experience with: Solid Edge untill ST4,
    Valued Contributor
    01-23-2013 12:01 AM in reply to: VdVeek
    Thanks but the post seems to be refering to the Display Style in the modelling environment, whereas I want to change the style of a drawing view.
    Wayne Helley
    *Expert Elite*
    mrattray
    01-23-2013 05:49 AM in reply to: waynehelley
    This is from VBA, experiment with it to make it work in iLogic.
    DrawingView.ViewStyle = kShadedDrawingViewStyle
    I'm not sure how familiar you are with coding in iLogic, but post back if you need more help.
    Mike (not Matt) Rattray
    Valued Contributor
    01-23-2013 06:14 AM in reply to: mrattray
    This iLogic code works for a drawing and changes all views in the selected sheet.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    ' select drawing views on active sheet
    Dim oDrawView As DrawingView
    For Each oDrawView In oSheet.DrawingViews
    'adjust drawing view style
    oDrawView.ViewStyle = DrawingViewStyleEnum.kShadedHiddenLineDrawingViewStyle
    'OPTIONS TO CHOOSE FROM
    ' kHiddenLineDrawingViewStyle = 32257
    kHiddenLineRemovedDrawingViewStyle = 32258
    kShadedDrawingViewStyle = 32259
    kShadedHiddenLineDrawingViewStyle = 32261
    kFromBaseDrawingViewStyle = 32260
    Next
    Valued Contributor
    01-23-2013 06:27 AM in reply to: mrattray
    Thanks Mike,
    I have been having a play around but haven't had any luck yet.  i though the following may work but Inventor can not recognise 'View Style':
    ActiveSheet.View("VIEW1").ViewStyle=kshadedDrawingViewStyle
    I get the folliwng error:
    Rule Compile Errors in Rule0, in 09090G00105414.idw
    Error on Line 1 : 'ViewStyle' is not a member of 'Autodesk.iLogic.Interfaces.ICadDrawingView'.
    Wayne Helley
    Valued Contributor
    01-23-2013 06:30 AM in reply to: VdVeek
    Thanks VdVeek
    Wayne Helley
