Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Daniel Davison
IV9 SP1 - Bug - iParts - Threads
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
48 Views, 8 Replies
11-10-2004 11:02 AM
Iparts do not update when you have a hole feature
that is a thread.
If the iParts were created before release 9 it seems to be OK.
If you create from scratch in Inventor Release 9 SP1 a rectangle
of say 1 in x 1 in and thread of say a .112-40 UNC (#4) and then
have the second row be 2 in x 2 in and a thread say .500-13 UNC
(1/2-13)
it will update the size but not update the thread.
This is not too much of a problem unless you are making Pem Nuts
that are round and when you change from a big size to a small
size it will error out.
Where do I go to have this resolved?
Is there an AutoDesk web site for bugs or is this it?
AutoDesk any help will be appreciated
Thank You
Dan Davison
*Daniel Davison
Re: IV9 SP1 - Bug - iParts - Threads
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2004 11:10 AM in reply to:
*Daniel Davison
Notice the thread is not changing. The Chamfer, OD, Insert Length is.
"Daniel Davison" wrote in message
news:4192659b_3@newsprd01...
> that is a thread.
> (1/2-13)
> Thank You
> Dan Davison
*Duncan Anderson
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2004 11:20 AM in reply to:
*Daniel Davison
http://www.sdotson.com/freetut/using%20threads%20i n%20iparts.pdf
HTH
Duncan
@home
"Humour ... is one man shouting gibberish in the face of authority, and proving
by fabricated insanity that nothing could be as mad as what passes for ordinary
living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
news:41926761_3@newsprd01...
> > that is a thread.
> > (1/2-13)
> > Thank You
> > Dan Davison
*Daniel Davison
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2004 11:21 AM in reply to:
*Daniel Davison
One other thing
On the "Tapped Hole Diameter" setting under "Document Settings", I use
"Drill Size" not "Minor"
Dan Davison
> that is a thread.
> (1/2-13)
> Thank You
> Dan Davison
*Daniel Davison
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2004 11:56 AM in reply to:
*Daniel Davison
Hi
Thank you. I have seen Sean's documents. This appears to be a bug.
"Duncan Anderson"
wrote in message news:419269fb_2@newsprd01...
> HTH
> Duncan
> @home
> proving
> ordinary
> living."
>> > that is a thread.
>> > (1/2-13)
>> > Thank You
>> > Dan Davison
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2004 12:29 PM in reply to:
*Daniel Davison
You have not defined a variable for the size of the hole. You must specify both the hole diameter AND the thread, not just the thread.
*Anne Brown
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2004 02:51 PM in reply to:
*Daniel Davison
http://www.autodesk.com/submitbug
This is your starting point for sending a message to Autodesk.
Use this form for general comments and questions, bug reports,
wish-list items, piracy reports, and so on
Anne Brown
Discussion Groups Administrator
Daniel Davison wrote:
(snip)
(snip)
*Daniel Davison
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-2004 04:15 PM in reply to:
*Daniel Davison
"Anne Brown" wrote in message
news:41929B70.E005A08E@autodesk.com...
> Anne Brown
> Autodesk, Inc.
> (snip)
> (snip)
*Shekar Subrahmanyam[Autodesk]
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-12-2004 07:25 AM in reply to:
*Daniel Davison
Hi Dan,
I"m not entirely sure if this is an issue.
For example, I tried the steps you suggested and created an iPart. In
this, if you go between row 1 and 2 you can see that the extrusion2 (hole)
size and the thread change accordingly. You need to make the hole diameter
also as a key. Isn't it? Thanks.
Shekar
news:4192aee9$1_1@newsprd01...
> Thanks
> > Anne Brown
> > Autodesk, Inc.
> > (snip)
> > (snip)
