Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Laimer, Leo
IV6 is the slowest...
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
65 Views, 20 Replies
11-07-2002 08:54 PM
Group,
I did some testing to compare the graphic speed of various CAD programs,
using the 8000cubes assembly and would like to bring the results to
everybodies attention.
The PC is a Dell 2.53GHz, with a Quadro4 900XGL. To get the frame rates I
used either the post statistics or a utility called FRAPS1.9.
shaded mode:
UGS18 62Hz
MDT6 8Hz
MDT5 7 Hz
IV4 4.33Hz
SW2001 4Hz
IV5.3 3.3Hz
IV6 2.7Hz
3d wireframe mode:
UGS18 72Hz
MDT6 24Hz
MDT5 22Hz
SW2001 3Hz
IV6 2.9Hz
Note: The 2d wireframe of MDT mode is very, very much faster, as has been
good old MDT3.01 in shaded/wireframe mode.
Definitely IV6 is by far the slowest package.
Leo Laimer
Maschinen- und Fertigungstechnik
A-4820 Bad Ischl - Austria
shaded mode:
UGS18 62Hz
MDT6 8Hz
MDT5 7 Hz
IV4 4.33Hz
SW2001 4Hz
IV5.3 3.3Hz
IV6 2.7Hz
3d wireframe mode:
UGS18 72Hz
MDT6 24Hz
MDT5 22Hz
SW2001 3Hz
IV6 2.9Hz
Leo Laimer
*Bilton, John
Re: IV6 is the slowest...
Options
- Highlight
- Email to a Friend
11-07-2002 09:16 PM in reply to:
*Laimer, Leo
Min Full LOD Frame Rate change to 7, Min Gift Wrap Tolerance set to 0.2 (Registry), Enable Overlays
and fastlinear-mipmap-linear in OpenGL settings of display properties and re-run the IV test,
because I can can get 25Hz with all parts visible on a 12000 part assembly in 5.3 with a lowly
Quadro2 card.
John Bilton
Quadro2 card.
John Bilton
*Boswell, Mark
Re:
Options
- Highlight
- Email to a Friend
11-07-2002 09:41 PM in reply to:
*Laimer, Leo
Min Gift Wrap Tolerance set to 0.2 (Registry),<----------How?
Mark Boswell
AEC Enterprises
Computer Specs:
Dell 530 Dual Xenon 1.8 1GB RDRAM
Quadro 4 900 XGL
"John Bilton" wrote in message
news:57AC585264633615A2FB4E5CDD4A7C8C@in.WebX.maYI adrTaRb...
re-run the IV test,
in 5.3 with a lowly
> Quadro2 card.
> John Bilton
Mark Boswell
AEC Enterprises
Computer Specs:
Quadro 4 900 XGL
"John Bilton"
re-run the IV test,
in 5.3 with a lowly
> Quadro2 card.
> John Bilton
*Bilton, John
Re:
Options
- Highlight
- Email to a Friend
11-07-2002 09:52 PM in reply to:
*Laimer, Leo
WARNING. CHANGING REGISTRY SETTINGS CAN MAKE YOUR MACHINE BECOME USTABLE AND IS NOT RECOMMNDED.
Run Regedit and change the following settings:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\Regis try6.1\System\Preferences\Display
You will find it under here.
John Bilton
John Bilton
*Laimer, Leo
Re:
Options
- Highlight
- Email to a Friend
11-07-2002 11:04 PM in reply to:
*Laimer, Leo
John,
I did as you recommended, and in adition swaped the driver to 41.03, but no
real difference.
The 8000cubes example is a tough thing - as it consists of simple cubes,
there is no geometry that can be simplified (or call it cheated) by the
driver. That's the reason why I use it to compare the graphic speed of
different systems.
It would be easy for you to compare the speed of IV to MDT - just save as a
sat file and open this in MDT. The graphic speed should be independent of
constraints, parametrics or features.
Leo Laimer
"John Bilton" schrieb im Newsbeitrag
re-run the IV test,
in 5.3 with a lowly
> Quadro2 card.
> John Bilton
real difference.
different systems.
Leo Laimer
"John Bilton"
re-run the IV test,
in 5.3 with a lowly
> Quadro2 card.
> John Bilton
*Bilton, John
Re:
Options
- Highlight
- Email to a Friend
11-07-2002 11:29 PM in reply to:
*Laimer, Leo
I will have a "play" myself when I get a spare moment. It could be another useful little routine
for my hardware bashing next month - will report back my findings and tests used.
John Bilton
John Bilton
*Caldwell, Larry
Re:
Options
- Highlight
- Email to a Friend
11-08-2002 12:05 AM in reply to:
*Laimer, Leo
I found it via search on LOD whatever that is. Thanks John, not really up on
that stuff, myself so I saved your post to refer to later ... if I can
manage to hang on to it, that is or worse, even remember it exist.
~Larry
news:37E42EF9A61F4464BD474EFD1BE912AE@in.WebX.maYI adrTaRb...
Display
> John Bilton
~Larry
"John Bilton"
Display
> John Bilton
*Laimer, Leo
Options
- Highlight
- Email to a Friend
11-08-2002 12:20 AM in reply to:
*Laimer, Leo
Now I'm really out of ideas...
Just tried to produce a 8000cubes array as features in a part file.
It took IV 12 minutes to create this (versus several seconds to do the same
array in an assembly file).
And then:
IV CAN ROTATE THIS WITH 59Hz!!!(shaded) and 100Hz wireframe!!!
Anybody can explain this?
Leo Laimer
"Leo Laimer" schrieb im Newsbeitrag
news:1C5D7219F294308B8B5C8330A56E44B4@in.WebX.maYI adrTaRb...
> Group,
> shaded mode:
> UGS18 62Hz
> MDT6 8Hz
> MDT5 7 Hz
> IV4 4.33Hz
> SW2001 4Hz
> IV5.3 3.3Hz
> IV6 2.7Hz
> 3d wireframe mode:
> UGS18 72Hz
> MDT6 24Hz
> MDT5 22Hz
> SW2001 3Hz
> IV6 2.9Hz
> Regards,
> Leo Laimer
And then:
Leo Laimer
"Leo Laimer"
> Group,
> shaded mode:
> UGS18 62Hz
> MDT6 8Hz
> MDT5 7 Hz
> IV4 4.33Hz
> SW2001 4Hz
> IV5.3 3.3Hz
> IV6 2.7Hz
> 3d wireframe mode:
> UGS18 72Hz
> MDT6 24Hz
> MDT5 22Hz
> SW2001 3Hz
> IV6 2.9Hz
> Regards,
> Leo Laimer
*Bilton, John
Re:
Options
- Highlight
- Email to a Friend
11-08-2002 12:45 AM in reply to:
*Laimer, Leo
It's definitely a Friday afternoon!
I'd go home if I were you
John Bilton
John Bilton
*Stocking, Matt
Options
- Highlight
- Email to a Friend
11-08-2002 01:23 AM in reply to:
*Laimer, Leo
just curious, what type of system are you using @ what resolution?
Matt
"Leo Laimer" wrote in message
> Group,
> shaded mode:
> UGS18 62Hz
> MDT6 8Hz
> MDT5 7 Hz
> IV4 4.33Hz
> SW2001 4Hz
> IV5.3 3.3Hz
> IV6 2.7Hz
> 3d wireframe mode:
> UGS18 72Hz
> MDT6 24Hz
> MDT5 22Hz
> SW2001 3Hz
> IV6 2.9Hz
> Regards,
> Leo Laimer
Matt
"Leo Laimer"
> Group,
> shaded mode:
> UGS18 62Hz
> MDT6 8Hz
> MDT5 7 Hz
> IV4 4.33Hz
> SW2001 4Hz
> IV5.3 3.3Hz
> IV6 2.7Hz
> 3d wireframe mode:
> UGS18 72Hz
> MDT6 24Hz
> MDT5 22Hz
> SW2001 3Hz
> IV6 2.9Hz
> Regards,
> Leo Laimer
