Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
IV2013 SP1 Forgetting Keyboard Customizat ions
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So this happened to me the other day. I'm trucking right along, doing the do like normal and then I notice a bunch of my keyboard commands no longer work. Not ALL of them. Some of them stayed.
At first I'm thinking that it's no big deal. I've exported my Customizations to an XML file and I can just re-import them., right?
So I did that. And yes, what I had saved in that file came back in. However, *SOME* defaults were returned at some point, so I still had to go line by line and scrub some things out to make them work. For example, I use "D" for general dimension in the drawing environment. But if the default setup had "DV" for detail view, "D" doesn't help because it's now an ambiguous entry. What a pain.
1. This is crazy that this happens. Seems like it's not a new thing either. What's the deal with elimination of this bug?
2. Is there a way to wipe all the keyboard commands prior to importing my own XML file so I don't have to manually scrub out other stuff?
Thanks!
Inventor 2013 64-bit SP1.1, single user
Win 7 Pro 64-bit SP1
Re: IV2013 SP1 Forgetting Keyboard Customizat ions
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
http://forums.autodesk.com/t5/Autodesk-Inventor/In
Similar problem here. Also - do you have this turned on: "Use default multi-character Command Aliases" in your customize menu.
Rob
