• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Re: IV2012 Error Message
    10-17-2012 12:31 PM in reply to: sbixler
    Hi, I know this is an older thread but I am having the same issue as the original poster.
    I am using Inventor 2013 Design Suite Premium on a  Windows 7 64 bit professional O.S.
    Inventor crashed on me and when I opened it up and went to change some dimensions on a sketch, the leader lines were there with no arrows and no dimension numbers. I was able to edit the dimension though. Figuring I might of changed the dimension style somehow I went to go into the Application options and got the same message as the OP.
    Was there ever a solution to this problem?
    Please use plain text.
    Distinguished Contributor
    BLHDrafting
    10-17-2012 05:45 PM in reply to: jabman81
    Only thing I can think of is doing a repair on the installation. Good luck.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
