• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    IV 2013 Factory Design Suite- Appearance adjustment/change in Weldment
    104 Views, 3 Replies
    01-29-2013 06:37 PM
    Hi
    I was wondering if there is a way to change the appearance of a face in a weldment assembly environment. I have a weldment which in the machining process a part of weld bead as well as a portion of one of the componets is machined down (spot faced) and I need to change the apprearance of those face to polished, but it doesnt let me do that? is it me, or its not possible?
    Warm Regards
    Please use plain text.
    blair
    Re: IV 2013 Factory Design Suite- Appearance adjustment/change in Weldment
    01-29-2013 09:16 PM in reply to: 3DAli
    Currently all the welds beads will change.  Select the weld bead (any weld bead) and then change the appearance from the Appearance drop-down menu and unfortunately all the weld beads in the assembly will change. Short of Photo-Shopping a picture I don't think it can be done
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Active Contributor
    01-30-2013 10:44 AM in reply to: blair
    yeah, I thought so, cause I tried different ways and unfortunately I couldnt, if it was in a part environment, it was easy as you can change the appearance of any operation generated face through properties in the right click menu.
    maybe a good one to add to wish list for future versions.
    Thank you
    Ali
    Warm Regards
    *Pro
    01-30-2013 10:50 AM in reply to: 3DAli
    Inventor IdeaStation is the place to do that.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
