• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: ITEM number - is it possbile to control it thru a part?
    04-30-2012 10:59 AM in reply to: Infoseeker
    nevermind
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Please use plain text.
    Valued Mentor
    jeanchile
    04-30-2012 12:26 PM in reply to: Infoseeker
    I don't have the time to do a search of the forum right now but this has been covered before. Someone has a blog post about it so search the Autodesk Blog sites as well. The basic step is you have to create a custom iProperty that the parts list and balloons both reference. Good luck.
    Inventor Professional 2013 (SP-1.1), Product Design Suite Ultimate
    Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (314.07), Space Pilot Pro (3.16.1)
    Laptop: Intel Core 2 Duo T9600 @ 2.8GHz, 8.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTS 160M (314.07), SpaceNavigator (3.16.1)
    Distinguished Contributor
    04-30-2012 12:32 PM in reply to: mcgyvr
    "People aren't totally against change (most of the time).. You simply tell them that the process of ensuring a drawings item number ONLY relates to 1 specific part number is not possible with your current software.Then propose simply using the part number instead."
    This is exacly what I did.
    I work for a big organisation that is at the point of transision from Autocad to Inventor, people come up with all kinds of weird ideas.
    04-30-2012 12:33 PM in reply to: jeanchile
    Already figured this out.
    Thanks.
    Doug_DuPont
    04-30-2012 01:40 PM in reply to: Infoseeker
    I do something what you are asking for. I have a customer that wants Part number, Code Number and Sheet number on each part.
    I find it easy to do that in the top assembly Bill of materials. Open Bill pf Materials and add a Custom iProperty Column for each custom property you want. Now fill in the fields in the part row. Now you can drag your custom iproperties down to all your other parts in your BOM just like you can in Excel.
    Select done and save, and all this gets saves to all yours parts. Then I need to change my parts list to show the new iproperty.
    Hope this helps.
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    04-30-2012 01:54 PM in reply to: Doug_DuPont
    I have all nesesery iproperties already incorporated in templates, sometimes I use BOM option as described by you.
    Why would you want to have a sheet numer connected to a part?
    Doug_DuPont
    04-30-2012 02:07 PM in reply to: Infoseeker
    A General Motoring customer of ours wants it that way. It goes back to the AutoCAD days of doing things. It adds more work to output it for them.
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    PaulMunford
    04-30-2012 02:54 PM in reply to: Doug_DuPont
    Is this the post that you were refering to?
    http://cadsetterout.com/inventor-tutorials/autodesk-inventor-creating-coordinated-bom-for-large-asse...
    There are some tips about half way down the page on using bubbles to call out custom properties...
    Paul
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    Doug_DuPont
    04-30-2012 03:02 PM in reply to: PaulMunford
    Paul,
    That is how we are doing it. That's a great step by step.
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    PaulMunford
    04-30-2012 11:18 PM in reply to: Doug_DuPont
    Cheers Doug :smileyhappy:
    @CadSetterOut
