• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    IProperties change on template
    112 Views, 1 Replies
    01-18-2013 01:54 PM
    Can sameone can help how to keep the Author and Designer name as capital letter
    Please use plain text.
    Curtis_Waguespack
    Re: IProperties change on template
    01-18-2013 02:38 PM in reply to: avi120
    Hi avi120,
    You can go to the Tools tab > Application Options button > General tab and retype the entry for the User Name setting using all CAPS.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
