• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: IPN View not shading correctly
    09-01-2011 02:50 PM in reply to: bobvdd
    Bob, thanks for the reply about the fixing in progress, and I hope you guys do find a common link to the errors in either situation as my renderings don't come out like they should. Any "glass" solids I have in multi-bodied parts come out solid.  That's where I would use the rotameter as an assembly.
    But working in the T&P module, assemblies are not the option for me (unless I understood incorrectly).  I was under the impression that once in the T&P assembly, constraints don't play nice with each other and the routing functionality.  If you have a link or a doc that supports otherwise, I would most humbly ask for you to provide.  Other than that, thanks for sticking to the problem and I will await AD fixes...
    - Aaron -
    IV 2010 Tube & Pipe SP4; ACAD Mechanical 2010;
    2.5 ghz Xeon Processor
    8 gb RAM
    Windows 7 Professional x64
    EVGA GTX 560 2gb DDR5
    Please use plain text.
    Distinguished Mentor
    -niels-
    09-01-2011 11:25 PM in reply to: bobvdd
    Yes, thank you for logging the issue Bob.
    I haven't had to render a multi-body in studio but it's good to know there are issues there too.
    Hope it gets fixed before or in the next release.
    Using IV2013 Pro SP1.1, Win7-64bit
    Product Support
    09-02-2011 08:12 AM in reply to: -niels-
    It also happens when deriving parts with transparent color. See this newsgroup discussion.
    I made our QA department aware of our not so good track record on this matter.
    To Aron's point of not being able to use assemblies inside a T&P assembly. I would like to understand your presumed limitation better. A priori I don't know of any obstacles in such a scenario. Can you elaborate?
    Bob
    09-02-2011 08:18 AM in reply to: bobvdd
    Bob, let me try and search for the post I saw about constraints within the T&P module.  I do remember a poster saying that they didn't work well together, but I could have misunderstood...
    - Aaron -
    8 gb RAM
