• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Dotson, Sean
    *** INVENTOR FAQ: NOV 25, 2002 ***
    15 Views, 0 Replies
    11-24-2002 09:46 PM
    ### Table of Contents
    1. Introduction and Rules & Regulations for the groups
    2. List of all the Inventor Support Newsgroups (web & newsreader)
    3. Frequently Asked Questions about R6
    4. List of Inventor Websites and Resources
    5. Bug Submission
    6. Common Acronyms Used in the Newsgroups
    PLEASE DO NOT CROSS POST TO MULTIPLE GROUPS. The exception to this rule is
    information
    that applies to all releases (e.g. this FAQ, the Inventor World Cup etc..)
    Post your question
    in the group to which version the question pertains.
    ### 1.Introduction
    Welcome Inventor users,
    Below are a list of several resources to help with your use of Autodesk
    Inventor. There is a lot of good information listed on these sites. Answers
    to the more frequently asked questions can be found in these links.
    If, after reviewing these sites, you still do not find the answer to your
    questions please feel free to post in the newsgroup. There are a lot of
    experienced users that will be more than happy to help you out if possible.
    PLEASE DO A SEARCH OF THE GROUP FIRST(see below).
    YOUR QUESTION HAS PROBABLY ALREADY BEEN ANSWERED.
    Please familiarize yourself with the ground rules for these discussion
    groups:
    http://discussion.autodesk.com/WebX?groundrules@57.JmmaaehooU3.0@
    Please be descriptive in your topic subjects. Subjects like "Inventor
    Problems" or "Inventor Question" do not lend much insight and are often
    skipped over. A topic such as "How do I loft several non-parallel sketches"
    is much more helpful.
    As some newsreader programs cannot display HTML formatted messages
    correctly,please be sure to post your messages in plain text format.
    Most newsreaders have an option to format the messages in this manner.
    If you are having display or crashing related issues please list your
    machine's specs: Processor, RAM, Operating System, Video Card, IV release &
    SP #. While it may not be due to these factors it helps to determine the
    cause.
    Do not post attachments in this group. You may post attachments in the
    CUSTOMER FILES newsgroup. Please move the end of part marker to the top of
    the file and/or zip the files to save space. You can find the customer files
    newsgroups here:
    WEBBASED CF:
    http://discussion.autodesk.com/WebX?14@67.Wd6TaaEbdXF^1@.ee940b5
    NTTP CF:
    news://discussion.autodesk.com/autodesk.autocad.customer-files
    ### 2. List of the Inventor Newsgroups
    As of Oct 30, 2002 the autodesk.inventor.support group was split into three
    separate groups.
    Below is a listing of each of the Inventor related groups and links to both
    the web based
    and newsreader versions of the groups:
    Inventor Main Menu
    http://discussion.autodesk.com/WebX?14@@.ee93814
    Inventor 6
    http://discussion.autodesk.com/WebX?14@@.f11e012
    news://discussion.autodesk.com/autodesk.inventor.6
    Inventor 5.3
    http://discussion.autodesk.com/WebX?14@@.f11e011
    news://discussion.autodesk.com/autodesk.inventor.5.3
    Inventor Legacy (R1-5)
    http://discussion.autodesk.com/WebX?14@@.f11e00c
    news://discussion.autodesk.com/autodesk.inventor.legacy
    Inventor Customization (VBA and VB)
    http://discussion.autodesk.com/WebX?14@@.f0935b8
    news://discussion.autodesk.com/autodesk.inventor.customization
    Inventor Support (old group - now read only)
    http://discussion.autodesk.com/WebX?14@170.faLLajGUn98.0@.ee77e6f
    news://discussion.autodesk.com/autodesk.inventor.support
    Webbased Search of all the Inventor groups:
    Google search of the Inventor Support Newsgroup
    http://groups.google.com/groups?hl=en&group=autodesk.inventor.support
    (I'll list the Google search of the other groups as they begin to show up on
    Google)
    ### 3. Frequently Asked Questions about R6
    1.) Where can I find SP1 for R6?
    http://support.autodesk.com/getDoc.asp?id=DL403697
    2.) Where did my print icon go in R6?
    You can access printing commands via File>Plot. To add the icon to your
    toolbar go to Tools>Customize and click on the last tab. Highlight
    Management in the left hand pane and then drag the print icon onto the
    standard toolbar in Inventor. You must do this for each file type. e.g.
    start a new part file and do this, then close and repeat with assembly,
    presentation and detail drawing file types.
    3.) Why do my decals appear as icons?
    You likely have .bmp file types associated with a viewer other than MS
    Paint.
    To fix this see http://www.sdotson.com/freetut/Tips%20&%20Tricks.pdf page 8
    item # 18.
    4.) Why do some of my project paths appear in red?
    There are nested paths. For example if you have a workspace defined as
    C;\project
    and a path defined as c:\project\parts the latter path will appear in red.
    See
    the Autodesk Inventor File Management Document.doc on the 1st AIS CD for
    more info
    about projects and how they work.
    Keep checking back. I'll add more as they develop.
    ### 4. Inventor Related Websites and Resources
    Drew Fulford's Inventor FAQ (Over 400 Inventor frequently asked questions)
    http://www.mymcad.com
    Sean Dotson's Inventor Tutorials & More (plus Inventor Benchmark Results &
    Software)
    Charles Bliss' iParts and iCode Repository
    http://www.cbliss.com/inventor
    Kent Keller's iParts and Code Site
    http://www.mymcad.com/KWiK/Mcad.htm
    Charles Bliss' Inventor Parts.com
    http://www.inventorparts.com
    Patrick de Stobbeleir's Inventor Tool Site
    http://hjem.get2net.dk/opad/
    Neil Munro's How-To Articles and Tips
    http://pointa.autodesk.com/local/enu/portal/inventor/tips/
    Ole Germer's Site (Timken bearings, Involute Gears, Roller Chains etc.)
    http://www.geocities.com/olegermer/index.html
    CAD Studio (Czech based but in English)
    http://www.cadforum.cz/cadforum_en/default.asp?tab=2&CAD=Inventor
    Elise Moss' Tips and Tutorials
    http://www.mossdesigns.com/
    The Netherlands Inventor Forum (mainly in Dutch)
    http://www.inventorusers.nl/index.php
    Lars Jensen's Inventor Site (Danish and English)
    http://www.inventordk.dk/
    Autodesk's Inventor Users Site (iDrop Parts, Articles & Tutorials)
    http://inventoruser.autodesk.com
    Autodesk Inventor Graphic Card & Driver Info
    http://support.autodesk.com/inventor-graphic-cards/
    Autodesk's Knowledge Base
    http://support.autodesk.com/enu/Homepage.asp
    Official Autodesk Inventor Feature Wishlist Submission Link
    http://usa.autodesk.com/adsk/item/0,,1073397-123112,00.html
    ### 5. Bug Submission Procedure
    ###Bug Submission
    If you think you may have found a new bug:
    1. Go to the Autodesk website: http://www.autodesk.com
    2. Click on "Contact Us".
    3. Click on "Ask a Question".
    4. Click on "Submit a Bug Report" from the drop-down menu
    of "About Our Products"
    5. Now you show see the "Bug Report Submission" web page.
    6. Read the instructions, fill out the form, and press the
    "Submit Bug Report" button
    Or directly go to the Bug Report Submission" web page:
    http://usa.autodesk.com/adsk/item/0,,1073063-123112,00.html
    More bug report info from Autodesk:
    "You can also either report it through your reseller
    or call Autodesk's Safety Net support number at
    800-225-6531. If it is determined that
    what you are calling about is a defect you will
    not be charged for the Safety Net call."
    ### 6. Common Acronyms Used in the Groups
    NG = newsgroup
    CF = customer files (see above for links)
    IV = Inventor
    R5SP2 = Inventor Release 5 Service Pack 2 (or any other combo of numbers)
    W2K=Windows 2000
    RMB = right mouse button
    DA = Design Assistant
    =grin = very big grin (etc..)
    ###PLEASE DO NOT RESPOND TO THIS POST.
    Sean Dotson, PE
    PS: If you have other sites that you think are useful or general comments,
    reply to me by email
    Delete all numeric characters in email to send
    Please use plain text.
