• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    ILogic rule for modeling/sheet metal state
    570 Views, 3 Replies
    10-06-2011 12:41 AM
    Hellow,
    Deos anyone know how what is the iLogic rule for identifying if a part is in a "modeling" state or "sheet metal" state?
    Shai
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: ILogic rule for modeling/sheet metal state
    10-06-2011 09:42 AM in reply to: shaiadle
    Hi shaiadle,
    You can use a conditional such as this to check for the existence of a flat pattern:
    If oSMDef.FlatPattern Is Nothing Then
    Here's a quick example:
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    'ensure this part has a flat pattern
    Dim oSMDef As SheetMetalComponentDefinition
    oSMDef = oDoc.ComponentDefinition
    'tell the user there is no flat pattern
    MessageBox.Show("This file has no flat pattern", "iLogic")
    Else
    'tell the user there is a flat pattern
    MessageBox.Show("This file does have a flat pattern", "iLogic")
    end if
    but to answer your question more directly, you can use the FlatPattern.ExitEdit method to return to the folded model, if the model is in the Flat Pattern environment:
    oSMDef.FlatPattern.ExitEdit
    and conversly you can use the FlatPattern.Edit method to return to the flat pattern, if the model is in the folded environment:
    oSMDef.FlatPattern.Edit
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Distinguished Contributor
    10-06-2011 10:45 AM in reply to: shaiadle
    If you're just trying to determine if the active document is a sheet metal part versus standard part this code may help.
    Dim curDoc = ThisApplication.ActiveDocument
    If curDoc.DocumentType = kPartDocumentObject Then
    	'This is a Part Drawing
    	If curDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    		'This is a SheetMetal Part
    		MessageBox.Show("This is a sheet metal part.", "SMCheck")
    	Else
    		MessageBox.Show("This is a standard part.", "SMCheck")
    	End If
    End If
    Rodney Thomas
    Design Engineer / Programmer
    A & A Manufacturing
    Support a Q & A For CAD Users: Stack Exchange Proposal
    Active Contributor
    09-10-2012 02:24 PM in reply to: rjay75
    Thanks Rodney,
    Is there a help resource where I can find the "text" for all the Sub-Types of files.
    I am trying to output them on the immediate window, but it seems to give me a troubles (or maybe I dont know how to get imformation on the Immediate window yet)
    Wajih
