• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    mrattray
    Re: iLogic set BOM via Visibility
    10-24-2012 12:26 PM in reply to: d_f_fleming
    Oops, my falut. I'm not good at multi-tasking! :smileyembarrassed: Find it attached to this post.
    By data set I mean your assembly and it's accompanying parts.
    Mike (not Matt) Rattray
    Please use plain text.
    Active Member
    10-24-2012 12:37 PM in reply to: mrattray
    I'm working for a tank manufacturing company.
    The data set is not something I can just post and I suspect is too large anyway.
    This is a large assembly with many parts.
    I created LOD's which I now know will not produce the BOM's I require.
    I created view reps from the LOD's and am trying to get ilogic to give me a BOM that reflects only the parts in the View rep.
    The code you sent is giving the same error but in lines 13 and 16 now.
    *Expert Elite*
    mrattray
    10-25-2012 05:06 AM in reply to: d_f_fleming
    Tanks as in military tanks? If that's the case, I imagine mentioning as much as you have could get you in trouble! :smileytongue:
    I have two theories as to why your having problems. Try this version, and if it doesn't work then we'll test theory two.
    Active Member
    mohan.nakka
    12-11-2012 02:51 PM in reply to: mrattray
    hi,
     anyone tried the code ?still have the same error messages in line 16 and 19
    Active Member
    mohan.nakka
    12-11-2012 02:52 PM in reply to: mrattray
    hi code doesnt work,please help
    *Expert Elite*
    Curtis_Waguespack
    12-11-2012 03:12 PM in reply to: mohan.nakka
    Hi mohan.nakka,
    There seems to be some mystery characters as shown.
    If you retype the word BOMStructure in both places shown it should take care of it.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Member
    mohan.nakka
    12-11-2012 03:27 PM in reply to: Curtis_Waguespack
    Thanks Curtis,
          That cleares the error message.I added this rule to an assembly file which has a view rep i created.i added this rule to fire with an event trigger "after save document".but none of the invisible components BOM structure is change to reference.Am i doing it right?Please help.
    Thanks a lot
    Mohan
    Active Member
    mohan.nakka
    12-11-2012 03:42 PM in reply to: mohan.nakka
    hi curtis,
              i created a sample assembly with few parts and tried the code,it works great.where should i use this code if i have sub assemblies in a top level assembly?
    Distinguished Contributor
    12-12-2012 07:15 AM in reply to: mrattray
    I treid this rule and unfortunately does not work for me, I suspect the reason is complicated BOM set up I use.
    Other guys did not complain.
    Active Contributor
    04-23-2013 08:17 PM in reply to: Infoseeker
    Why does this only work in Master LoD???
