• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    AhmetSevik
    Accepted Solution
    IDW file format update to all my old idw files
    159 Views, 7 Replies
    02-02-2013 05:47 AM
    I am user for Inventor 2013 Professional.
    1 year ago i created a format for my idw template file. I set many things under Drawing Resources in browser.Sheet Formats, Borders, Title Blocs, Sketch Symbols... etc. Now we want to change something in this resources and i will create new one.
    My question is if i create new one, then can i update all new formats to my old idw files? I mean, i can't open all of old files and i can't change one by one. I want to do in easy way.
    Thanks.
    Ahmet ŞEVİK
    Please use plain text.
    New Member
    Re: IDW file format update to all my old idw files
    02-02-2013 07:08 AM in reply to: AhmetSevik
    i think there's a way to save your old files to 2013.
    *Expert Elite*
    blair
    02-02-2013 09:28 AM in reply to: AhmetSevik
    Have you looked at the: "Drawing Resource Transfer Wizard" that is shipped and installed with Inventor. It's located within the Inventor>Toold of the Start Menu
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    *Expert Elite*
    blair
    02-02-2013 10:55 AM in reply to: AhmetSevik
    Here's a good link: http://blogs.rand.com/manufacturing/2011/08/all-my-inventor-drawings-need-a-different-title-block-ar...
    Win7-64
    AhmetSevik
    02-02-2013 11:05 PM in reply to: AhmetSevik
    I solved my problem with Drawing Resource Transfer Wizard. I did'nt see till now this wizard under start menu.
    Just one point; if your files saved with different inventor version then this wizard couldn't succes to convert. Then you should to open your old file with your inventor and you have to save again with new version. Then Wizard work.
    Thank you very much to all of your helps. Thanks.
    *Pro
    02-03-2013 02:16 PM in reply to: AhmetSevik
    If your files need to be migrated, use the Task Scheduler, also in the Start menu.  You can set up a Migrate task for a project or folder, or select individual files.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    *Expert Elite*
    blair
    02-03-2013 02:50 PM in reply to: AhmetSevik
    If you have any custom material/appearances, migrate them first. Good documents on the Autodesk website. I follow the following procedure when migrating.
    1.) Have a good copy of your data. We have all data stored to a external USB drive. This is much easier to recover than having to restore from a Back-Up.
    2.) Run the Task Scheduler and migrate all IPT's first
    3.) Run the Task Scheduler and migrate all IAM's next
    4.) Run the Task Scheduler and migrate all IPN's third
    5.) Run the Task Scheduler and migrate all IDW's last
    Win7-64
    *Pro
    02-04-2013 04:00 AM in reply to: blair
    Blair, good point about the material/appearance migration.
    As for the file migration, my experience with Task Scheduler is that it performs the migrations in the proper order, so you don't have to do it four times.
    Sam B
