• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    IDW Trouble INV 2008
    42 Views, 2 Replies
    07-11-2007 07:03 AM
    We just installed INV2008 from INV 11 and now I cannot create idw. I have opened and saved our templates as the new version which is all I remember doing when we went from 10 to 11 but it hasn't worked this time. If anybody can help here I would appreciate it. Thanks.
    Mark
    Please use plain text.
    karthur1
    Re: IDW Trouble INV 2008
    07-11-2007 07:28 AM in reply to: mdilger
    What happens when you try to create a new idw?
    Is you project set correctly?
    *Dennis Jeffrey
    07-11-2007 07:47 AM in reply to: mdilger
    Please do not create duplicat posts a couple minutes apart...
    Here's some tips from your OTHER post on this....
    It currently appears that install issues are user specific. Now that's not
    an answer, but after installing software for way over 20 years, just the
    voice of experience. There are several reasons why software (and updates)
    fail:
    1. Operating System service packs and hotfixes not up to date. That means
    Windows 2000 sp4 and Windows XP sp2 at minimums.
    2. Insufficient disk space on C: (Yes
    3. Temp folders full. Empty all temps regularly, AND before installs.
    4. Hardware: Defragment HDs regularly, Proper Graphics Cards and certified
    drivers, Insufficient Virtual swap space.
    5. ANTIVIRUS!!! Antivirus MUST be turned off. No antivirus services
    running. Norton and McAffee are absolutely the worst for creating bad
    Installs. If you cannot verify that they are totally OFF, then temporarily
    uninstall them.
    6. Conflicting Installed programs - Make sure that all installed Autodesk
    products are at their latest SP release. I just found a system yesterday
    that had Inventor 10 ( no SPs) installed, preventing a silent install of
    2008.
    7. Close ALL programs prior to installing software. Make sure that they are
    not still running in the background.
    8. Shut down ALL UNNEEDED services before installation. Go to Control
    Panel - Admin Tools - Services to stop services. Just RMB on each and select
    Stop. On reboot, they will all restart if you have not modified the
    startups.
    9. ONLY install with FULL Computer Administration Rights
    10. ALWAYS Read the instructions or Readme files thoroughly. ( This one is
    for all us guys who think they can assemble a BBQ Grill without the
    instructions....:smileyhappy:
    11. If you still have issues, call your reseller for assistance.
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert.
    260-399-6615
    Instructor/Author/Sr. App Engr.
    AIP 11SP3, AIP 2008 SP1
    HP zv5000 AMD64 ( modified)
    Geforce Go 440, Driver: .8185, 2GB RAM
    XP Pro SP2, Windows Classic Theme
    wrote in message news:5653822@discussion.autodesk.com...
    Mark
