• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    dominik.gleinser
    ICopy: "This ICopy-Element can't be edited..."
    147 Views, 3 Replies
    04-20-2012 12:05 AM
    Hallo,
    I have following problem with ICopy:
    Edit with ICopy:
    When I'm doing this, I get following error message: "Dieses ICopy-Element kann nicht bearbeitet werden, da die Struktur der Vorlagenbaugruppe verändert wurden"
    In English: "This ICopy-Element can't be edited, because the structure of the original assembly has been changed"
    Please use plain text.
    Product Support
    Re: ICopy: "This ICopy-Element can't be edited..."
    04-24-2012 02:39 AM in reply to: dominik.gleinser
    The exact message in english is :
    Cannot edit this iCopy feature because the structure of the template assembly is changed
    You probably did a change in the Icopied Assembly. I think the best way is to delete this Icopy and reinsert it.
    Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
    dominik.gleinser
    04-24-2012 03:30 AM in reply to: pierre.masson
    Thank you for your answer,
    but I have already tried to reinsert the assembly....the same problem again!
    Do you have other solutions?
    Product Support
    04-25-2012 03:22 AM in reply to: dominik.gleinser
    Perform a complete rebuild all of the assembly (vi Task scheduler), and reauthor it with Icopy.
    Then try to reinsert. If this does not work, please send it to me.
