• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Passi
    Accepted Solution
    I2010: Can I create a round sheet metal strap jog between two different straps?
    301 Views, 2 Replies
    12-09-2011 01:24 AM
    Hi there,
    in Inventor 2010 we have a sheet metal, with a lot of different straps. But we cannot create round jogs between them. It's only possible, if all straps are created at the same time with the same size etc.
    Please see the attached file. The upper version, is the one, it looks in the moment and we want an apperance like the lower one.
    Is it possible? Because we cannot add all the round holes later on in development of the sheet metal.
    Best Regards
    Passi
    Please use plain text.
    Product Support
    Re: I2010: Can I create a round sheet metal strap jog between two different stra
    12-12-2011 06:24 AM in reply to: Passi
    When you create two adjacent flanges at the same time a Corner Seam is automatically applied.
    If you create them using two seperate functions then you need to apply the Corner Seam manually.
    Just make sure your "Sheet Metal Defaults" are set correctly.
    Jon Dean
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    Passi
    12-13-2011 03:19 AM in reply to: Passi
    Perfect :smileyhappy:
    Thx a lot
