• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    I need to limit motion when one part touches (bumps into) another.
    130 Views, 2 Replies
    12-21-2012 06:49 AM
    I'm using inventor 2009.
    I haven't been able to find a solution but can't seem to locate in here in discussion groups.
    I need to limit motion when one part bumps into another.  I am an occasional user and cannot seem to find this in the help files or tutorials.
    Thanks in advance.
    ACAD 2010
    ACADE 2008
    AIS 2009
    Please use plain text.
    Curtis_Waguespack
    Re: I need to limit motion when one part touches (bumps into) another.
    12-21-2012 07:07 AM in reply to: jjs38
    Hi jjs38,
    You can use the Contact Solver tools to do this. Here are a couple of links on the subject:
    http://inventortrenches.blogspot.com/2011/01/contact-solver.html
    http://inventortrenches.blogspot.com/2011/06/assembly-challenge-mating-spherical.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    12-21-2012 12:01 PM in reply to: Curtis_Waguespack
    Thanks thats what I was looking for.  Knew it was there, just couldn't find it.
    ACAD 2010
    ACADE 2008
    AIS 2009
