• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    I need help - Knife Blade
    307 Views, 9 Replies
    01-10-2013 08:27 AM
    ok so im making a knife and i have the sketch done. i etruded it to 3mm i then put the edge on it on all the sides except for the pointed part it says that the comand is to difficult to do. any help would be greatly welcomed.
    Edited by
    Discussion_Admin
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: I need help.
    01-10-2013 08:49 AM in reply to: jacob.hawk.fcp
    You could create the shape, then use the chamfer tool to apply the desired edges.
    Something like this part attached.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Valued Contributor
    Re: I need help.
    01-10-2013 08:52 AM in reply to: jacob.hawk.fcp
    What about this?  I modified your part.
    Eric
    Please select "Accept as Solution" if this answers your question.
    *Expert Elite*
    Re: I need help.
    01-10-2013 08:55 AM in reply to: jacob.hawk.fcp
    First thing I notice is that your sketch is not fully constrained.
    Second thing I notice is you have a bunch of repeated dimensions that are not needed. (see attached)Repeated Dimensions.png
    Let's start this thing over again from scratch.
    Sketch a single line horizontally from the origin over to the right and dimension it 173.015
    Attach the file here.
    Valued Contributor
    Re: I need help.
    01-10-2013 08:58 AM in reply to: JDMather
    I noticed the same thing, but didn't want to get into teaching a basic Inventor class.
    Eric
    *Expert Elite*
    Re: I need help.
    01-10-2013 09:01 AM in reply to: EScales
    First post by OP - we should get them doing the basic stuff right before they develop bad habits.
    Valued Mentor
    mpatchus
    Re: I need help.
    01-10-2013 09:10 AM in reply to: JDMather
    I couldn't open his part since it is done in 2013.
    Wasn't aware that the sketch geometry was unconstrained.  :mansad:
    Way to straighten him out JD!
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Active Member
    Re: I need help.
    01-10-2013 12:23 PM in reply to: EScales
    hey thanks how did you do this so i know for future sketches?
    Valued Contributor
    Re: I need help.
    01-10-2013 12:31 PM in reply to: jacob.hawk.fcp
    Take a look in the browser of the part.  I added Sweep1, Sweep2 and Mirror1, before your Chamfers.  You can see where I created a sketch at the end of the straight portion and swept the triangular portion around the curve to the tip.  I did that twice and then mirrored both of those to the other side.
    Eric
    Active Member
    Re: I need help.
    01-15-2013 06:07 PM in reply to: mpatchus
    The part attached is mine, but if you look the point it wont come together Jacob Hawk
