• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Karol-Or
    I cannot make the Keyway in the hub
    161 Views, 6 Replies
    12-14-2012 11:37 AM
    I use the Key Design Accelerator, i suceded in making the Keyhole in the shaft, but cannot complete the selection for the hub.
    I selected the 2 hub's faces, but am stuck in the third and last selection box for the hub, the Second Reference
    Please use plain text.
    Distinguished Mentor
    Re: I cannot make the Keyway in the hub
    12-14-2012 01:08 PM in reply to: Karol-Or
    Reference 2 for the hub is the ID (circle).  See attachment.
    John Retzlaff
    Active Contributor
    Karol-Or
    12-14-2012 11:25 PM in reply to: john.retzlaff
    How did you select the circle that you showed me in the picture you attached?
    It is hidden behind a part, and when i pause over the approximate location-nothing appears, i don't get the ability to choose hidden objects, i don't get the small green square with the 2 arrows, i don't know how it's called
    Active Contributor
    Karol-Or
    12-15-2012 01:40 AM in reply to: Karol-Or
    Even if i turn off visibility of the obscuring feature i still cannot select the circle you showed me
    Active Contributor
    Karol-Or
    12-15-2012 01:00 PM in reply to: john.retzlaff
    I want the keyway to be only in the gear, not the circular plate which is around the shaft.
    If i select the 2 faces of the gear i cannot select the bore of the gear, only if i select, a one of the faces, the circular plate then the keyway in the circular plate is created.
    That isn't my intension.
    Active Contributor
    Karol-Or
    12-15-2012 01:15 PM in reply to: Karol-Or
    It seams i cannot make a keyway in the gear, maybe because it's an iFeature? is it an iFeature?
    12-15-2012 01:32 PM in reply to: Karol-Or
    There is no hole in the gear. Try putting a hole in the gear.
    John Retzlaff
