• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    I can´t see the whole screen
    157 Views, 7 Replies
    01-08-2013 12:12 PM
    Hi to everybody
    Well I have tried with different resolutions, but even with the highest one 1366x768 I can´t see all the panels on the Inventor screens. It´s like my screen is to small to show all the windows inventor has.
    How can I solve the problem?
    I attach an image to show the problem, I can´t see what´s under the "point alignment" option, I can´t see the "accept" nor "cancel" buttons.
    I tried to search on google and here in the forum but I couldn´t find anything, I hope not to ask something has already been asked before.
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: I can´t see the whole screen
    01-08-2013 12:16 PM in reply to: santifis
    the system requirements say you need at least a 1,280 x 1,024 or higher screen resolution
    system requirements are here: http://usa.autodesk.com/autodesk-inventor/system-requirements/
    if your resolution is to small not sure if you can do anything about it
    Member
    01-08-2013 12:27 PM in reply to: DarrenP
    Ups, I didn´t know that, thank you for your reply. At this moment it´s a nightmare but I have a tip to select the buttons I can´t see, I use the tab button several times and click, sometimes I click cancel, sometimes accept it´s like guessing.
    Maybe that helps people with the same problem.
    Distinguished Mentor
    -niels-
    01-08-2013 11:27 PM in reply to: santifis
    Do a google search on "infinite screen", it's freeware that allows for scrolling a virtually larger desktop.
    I haven't tried it myself, but maybe it helps.
    Otherwise you can always search for other virtual desktop software.
    Using IV2013 Pro SP1.1, Win7-64bit
    *Pro
    01-09-2013 04:43 AM in reply to: santifis
    Look carefully at your display settings.  Some graphics systems (Nvidia comes to mind) will have settings that allow you to expand your desktop to a larger resolution than the actual screen. The desktop scrolls when your cursor hits the edge of the screen.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    *Expert Elite*
    01-09-2013 04:48 AM in reply to: santifis
    santifis wrote:
    ..., I use the tab button several times and click, sometimes I click cancel, sometimes accept it´s like guessing.
    I used to have that problem in classrooms on data projectors that at the time didn't support high resolution.
    My solution was to count the number of tabs needed from a particular location and memorize.
    Valued Mentor
    stephengibson76
    01-09-2013 05:13 AM in reply to: santifis
    or use your video settings to rotate the screen, click ok and then rotate it back
    Stephen Gibson
    Autodesk Product Design Suit 2012
    Win 7 Enterprise 64bit
    Intel core i7 2600K Clocked @ 4.7GHz
    16Gb Ram
    Nvidia GTX 580
    Member
    01-09-2013 07:27 AM in reply to: sbixler
    Thank you to everybody.
    FInally I solved the problem changing one of the display options, I had medium display 125%, I changed it to default 100% and now I can see everything, I´m very happy. I didn´t even know that I had the 125 option activated.
    Before that I tried windowslider, unfortunately the desktop is infinite only in the left to right direction, but nothing changed in the top to bottom  direction, so it didn´t solve the problem.
    I didn´t test the option of rotating the screen since it is solved, sorry.
    See you in other threads friends!
