• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    I can no longer Click "Realistic" when choosing my visual Style
    93 Views, 2 Replies
    12-03-2012 04:41 AM
    When doing presentations I always use Realistic.  However today I turned on my machine and wanted to choose this visual style but I can't. I have tried playing around with the options>Hardawre>Quality instead of my regular Performance.  I have tried everything I can think of.  Please I need Help!!!!!!!!
    See attached for my Hardware Diadnostic
    Please use plain text.
    Active Member
    Re: I can no longer Click "Realistic" when choosing my visual Style
    12-03-2012 04:46 AM in reply to: Ryan.Irwin
    I forgot to mention.  I am using 2013 and recently did an update (Nov 26, 2012) but i thought i used realistic after the update.  Could be wrong though.  Should I uninstall this update??
    Valued Contributor
    Mark.Downes
    12-03-2012 07:21 AM in reply to: Ryan.Irwin
    I had a similar thing happen when i upgraded from 2012 to 2013. I uninstalled 2012 and things
    went a bit wobbly from then.
    Try remapping your IPJ file (Get Started / Projects menu) apperance & material database libraries files,
    just scan for your .adsklib and re-link them to your directory.
    Hope this helps
    Mark
