• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    I WANT TO KNOW HOW TO GIVE THE HEIGHT FOR ARC IN ACAD INVENTOR
    163 Views, 4 Replies
    11-07-2012 06:57 PM
    Please use plain text.
    Re: I WANT TO KNOW HOW TO GIVE THE HEIGHT FOR ARC IN ACAD INVENTOR
    11-08-2012 12:56 AM in reply to: viveksriramr
    This question has been answered here within the past 5 days.
    A search should turn up the solution.
    What version of Inventor are you using?  (solution depends answer to this question)
    Actually I read this as arc length.
    But if you really need arc height - simply create construction line and dimension.
    If you attach your ipt file here it might be clearer what you need to solve the problem.
    Active Member
    11-13-2012 07:33 PM in reply to: viveksriramr
    The part is attached, i want to take the overall height of the tile.
    Active Member
    11-13-2012 07:35 PM in reply to: viveksriramr
    we are using Acad Inventor 2013.
    blair
    11-13-2012 07:46 PM in reply to: viveksriramr
    For the record it's Autodesk Inventor, not sure what Acad is.
    You could dimension from the edge to the mid-point of the arc to get the height (crown) of the arc.Capture.JPG
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
